Nx Maf Question
Old Nov 28, 2004 | 10:20 PM
99HUGGSS's Avatar
Default Nx Maf Question
I checked with NX and my soleniods will support a 300 shot. Is it possible to Y off of the bottom of the solenoids and use the 1st and second stage both at once? I spray 150 through the top right now, I want to spray an additional 100 through the bottom. I don't see why this won't work, but then again I am no expert. Any and all help is much appreciated
Old Nov 28, 2004 | 10:22 PM
Nitro Dave's Nitrous Outlet's Avatar
If you are palnning on using one set of solenoids I would spray just one side of the plate 250 hp.The reason why is that with all the connections you will not see the 300 hp out of the solenoids.
Dave
Old Nov 28, 2004 | 10:26 PM
99HUGGSS's Avatar
each stage of the NX MAF kit is maxed out at 150hp. Would I have to jet it for 150 at each stage just to hit 250? I know this probably sounds weird, please forgive my ignorance
Old Nov 28, 2004 | 11:36 PM
Elite_Hot_Rod's Avatar
Probably. I run the same system with it set at 150 on each side and it only makes 250 but the one side is set rich for a little insurance.
Old Nov 29, 2004 | 08:17 AM
99HUGGSS's Avatar
sweet, I appreciate it. I think I'm gonna try it
Old Nov 29, 2004 | 08:44 AM
Each side of the maff will support 250 hp.The solenoids that come in the system will support 300 hp.The problem is that when you try to split off of one set of solenoids there is alot of flow restrictions.This will limite the horse power gain.
Hope that helps.
Dave
Old Dec 2, 2004 | 08:27 PM
GueSS Who's Avatar
Hope that helps.
Dave
Maybe this has to do with the -3 line running to the nozzles because I have tried this on multiple cars including mine and can only get 150 out of the top and 150 out of the bottle with each stage running its own set of solinoids and relays. They are pilled for much higher but could never make the power needed. I ended up using the top part of the maf as one stage and a NX nozzle for the other stage. I am now spraying 350 with the setup. Works like a champ.
Old Dec 2, 2004 | 10:02 PM
Send us the plate and we can check it ot.But you may be right with those 90s in there it may need the sho hose.
Dave
