Purge Line
Old Dec 6, 2004 | 10:42 PM
99Ws6TransAm's Avatar
Default Purge Line
What is a good line to use for purge? I wanna run it up to my notrils in my WS6 hood..and T it out right there so theres 2 outputs.
Old Dec 7, 2004 | 12:22 AM
17WITHaBIRD's Avatar
i got some copper line and used a t to make the duel purge at the windshield
Old Dec 7, 2004 | 03:36 AM
BottleRocket's Avatar
yeah, copper tubing will work. Ive seen some use heater hose, but it can probably freeze. Where are your solenoids mounted?
Old Dec 7, 2004 | 05:35 AM
sz0077's Avatar
i got some plastic tubing with my solenoid- it froze and cracked the 2nd time i purged- dont use it. i gotta fab up something out of copper so i can get back to the nitrous the right way
Old Dec 7, 2004 | 09:34 AM
marlowchris's Avatar
I used 1/8" copper tubing. you can get it from any parts house. It is typically used to plumb gauges. You can also get it in 3/16", but I prefer 1/8". It is easy to bend and there area wide assortment of compression fittings avaliable.
Old Dec 7, 2004 | 12:36 PM
Gregg 00SS's Avatar
You can also use steel braided hose for plumbing, that is what I used. I think it is called "iceman" whatever, picked it up at a local plumbing shop.
Old Dec 7, 2004 | 01:56 PM
thats a little pricey, the copper is cheaper and works just as well
Old Dec 7, 2004 | 02:53 PM
Gregg 00SS's Avatar
True, was about the only thing I could use for my set-up. I have my purge coming out the scoop on my SS. So I needed something I could route up there, and copper tubing wouldn't cut it. I did use copper tubing from the entry into the scoop out to the honey comb. I recently got a dynotune purge thingie so gonna reroute everything seeing I will only need 1 line coming from the purge silenoid for a dual purge.
Old Dec 7, 2004 | 05:48 PM
TigerFan187's Avatar
I just bought a 3/16" x30" section of copper brake line for my purge setup like an hour ago. It was like $2.20 with the end on both sides. Pretty cheap way!
