anyone running the cold fusion direct port?
Retired Street Racer
i was wondering if anyone is running the cold fusion direct port kit. i am looking to get this or a similar setup but there is not a lot of info about this kit, for around a 150-200 shot now, and 250-300 later on. thanks, Matthew.
12 Second Truck Club
I'm spraying almost a 200 shot on stock bottom without a problem. Direct port would actually, from what I've read, be easier on your engine than a single nozzle. You get better distribution and more even power. If you also have a progressive controller, I definitely think a 200 shot would be fine.
I have the Cold Fusion EFI Dirrect Port on my car. Set on 350hp right now.
It's a great kit. Very clean, and the install is straight forward. I do recommend a separate fuel system for the nitrous though, as the pressure drop at the rail happens very drastically if you are running it on the primary fuel system.
