Pics of installed TNT F1 PLEASE
If you have this kit installed please post pics or send Private Message (pm). Also any tips or tricks to the install would be appreciated, also anyone mounted bottle in spare tire compartment have pics and instructions?oredered kit and racetronix fuel pump yesterday and cant wait to install it!!
THANKS
THANKS
attached is a pic of my F1 kit installed, and of my bottle in the spare tire compartment. if you want anymore pics let me know, i think i have a few laying around.
tips for F1 installation: you may have to cut your lid to make it all fit, i used a dremel tool and took off a little bit at a time until i had a perfect fit. also, fitting the ring over the throttlebody was not easy, so you might want to take the throttlebody off and install the ring, then put it all back on the intake
hope tis helps, good luck!
Originally Posted by Tiger2o69
Sorry to double post but did u have to buy another bellow or will the stock one work?
Ill be posting my install pics Today onmy 2003 EC Silverado. I ended up having to mount the two nozzle directly into the throttle body because the power-ring wouldnt fit with the FIPK2. Anyone wanna buy a powerring that looks brand new. It is the silver one less the nozzles.
be a good idea to run a timing tuner as well..
im in the middle of installin my kit...and have run into some set-backs...which of course are all apart of moding a car. just remember, its never truely a "bolt on" kit...lol. i found that out real quick.
good luck!!
good luck!!
nothing major..again..things you'll run into....i had to get a hose extension (main nitrous feed -6an) i guess cause of where i mounted my bottle (down in the t-tops)...solinoids didnt fit properly on the bracket supplied, had to fab it up a bit..had to get differant fitting for the solenoids again b/c where its mounted, purge line wouldnt fit, it would hit the air lid...other than that, after finally getting into everything and realizing you need couple extra things....you never realize it till it comes up and your like..**** i need something else..(fittings, couplers, etc.) like i said...nothing major...all a part of modifications.. fun times...luckely its not a daily so i work on it sparingly. once again..goodluck.
