nitrous measurement
TJ
TJ
Yup, that would be correct, it is easier to mesure fuel flow ( I would think ). You know that you have to have a linear ratio between fuel and N2O, so whater ever makes the most power/fuel is the more efficient kit, granted ALL else is equel.
My fuel pump is not able to handle consistantly more than 150 shot (wet). Why would I be happy spraying a number which I am unsure about.
Atleast NX says 150 and you are getting 148-152. Their website claims a 2 horsepower difference from their rated numbers ( and NX is to the wheels also ).
I just dont see how people can be so ignorant sometimes when it comes to putting your engine in harms way
with any kit (nx, tnt, nos, edelbrock, zex, etc), anyone spraying should get themselves on a dyno and do a few nitrous runs on the spray, to make sure their a/f ratio is ok. no ignorance involved as long as you do it right
TJ
Ron 00Z, everyone I know, when wanting to measure nitrous consumed weighs the bottle before the run and after. Memory here: 1lbs of nitrous per 100hp every 10sec; running 100 jets, ET of 11.70 I use just over one pound, average about 7 runs per bottle, spraying out of the hole and thru the shifts, with the 7th being slower (unless the bottle is hot). Should be about there though.
Off Topic: The nozzle design contributes to atomization which will increase or decrease power output, as well as max power e.g. you can run a jetless 5177 kit and not spray more than what 150hp! Thats with no jets. Take the jet out of one of the wet kits, block of the fuel side and run that on a dry kit and see what you get! Also, although the jets are supposed to be universally stamped according to orifice size, I believe there is a difference in the TNT Jets orifice and others, or theres just a bigger difference in the recommended fuel to nitrous jetting pattern attributing to the difference in power. My experience is that NX is not as close to 2hp, more like 5-8%, normally under which is due to the safer AFR using the NX jet charts. TNT kits have shown closer to the advertised, if not over, but also have a leaner AFR than NX. I prefer the richer jetting, and then dial it in for my particular combo. And if given the choice, I would use the NX MAF kit over any other wet kit out there, including the TNT Power Ring.
Just my $.02
Charlie
Just my $.02
Charlie
