NX stage 1 single nozzle ?
*do i have to rethink about the NX stage1 because of the single nozzle ? ( am going to use the 150 hp jet )
thanks ...
i also heard something about that the 2 nozzle has a better response after spraying . is it true ..?
one more thing do u deal internationally ?
my injectors r 28s not 26 and my car not an F body its Holden Commodore SS powered by LS1 of course .
That cam will work with nitrous.
Where are you located, and what were you interested in? A motor or something would be pretty expensive, but a nitrous kit is probably doable although Im not sure about the bottle? I can find out though.
I have no clue as to the specs of the Commodore's fuel system. If it is anything like the F-body you will be fine with a 150 shot on a stock motor. I ran a 150 shot on a cam only motor also w/o problems. Start adding heads and cam and you want to start thinking about at least a pump.
am thinking about small stuff like the nitrous system and some thermostats
to Saudi Arabia .. awww seems far haa , i usually get my stuff from summit but am looking forward for professional tech support .
