spray at filter once mafless?
Old Dec 25, 2004 | 10:58 AM
thenewb's Avatar
Default spray at filter once mafless?
hey, i was wondering if you could punch a hole thru the air filter (like you can on a dry shot) and spray from there with a wet kit if you went mafless. i don't want ppl looking at the kit but want an extra "boost" when the going gets tough.
i'm ordering a wide band system and HPTuners here this winter so i will be going MAFless
any thoughts from the pros? don't want it to puddle but want to keep a wetkit hidden as best as possible.
wetkit is a must as i need a good N/A tune and my stock 02 injectors will be at there max (242/248 .610/.615 cam on a 111 lsa and a set of hoome ported heads milled .030) the pistons are flycut .100 but many ppl have told me the rings will still go long before and it will be a very safe tune, only spinning to 6900 on spray.
Old Dec 25, 2004 | 11:47 AM
ATVracr's Avatar
That doesnt sound like a good Idea at all.
Old Dec 25, 2004 | 12:11 PM
thenewb's Avatar
any reasoning behind that?
Old Dec 25, 2004 | 01:12 PM
jamnut's Avatar
6900 is pretty high to spin a motor on the spray. You'll get away with it for a while, but after that, you are on borrowed time.
As far as spraying through your filter like that, that's not a good idea either. these nozzles are designed for a certain spray pattern, with the nozzle in your air box the spray pattern it going to really expand then have to bottleneck back down to go through the bellow's & TB. That's gonna give you a bad distribution problem. I predict meltdown on some of the back cylinders.
Old Dec 25, 2004 | 04:50 PM
thenewb's Avatar
where else can i hide it that would be better?
Old Dec 25, 2004 | 05:09 PM
jamnut's Avatar
I run a single nozzle into the bottom right side of my bellows, I have a smooth bellow's. My noids are bolted to my fan shroud under the radiator hose & hidden beneath some black wire tubing. I have all of my nitrous lines run through the same black convoluted tubing & I cover the blue nozzle with electrical tape to make it match the black of the tubing & the black of the smooth bellow's. It's pretty stealth for a wet kit.
Old Jan 2, 2005 | 11:06 PM
thenewb's Avatar
where do you run the line for fuel? the shrader valve would be obvious for someone looking for spray on a car...
Old Jan 3, 2005 | 08:43 AM
BMN's Avatar
BMN
That's your big problem now. You would have to do a standalone fuel cell pump, but now how u gonna hide that. If you kept your MAF you could run a dry shot to hide it real easy. Does HP Tnrs have some kinda input to swith over to a different fue/timming map once your N2O is activated? Then a dry would work with it.
Old Jan 3, 2005 | 03:41 PM
thenewb's Avatar
28.8 injectors, LARGE cam, ported and .030 milled heads, .110 cut on the pistons.....
AKA- maxxed out injectors
