Dry on M6/cam only/ without bigger injectors?
Iam running a 224/224 cam with longtubes and was wondering if I could run a 75 dry shot with out getting bigger injectors. My car is a 01 with the 28lb injectors. I have a 255lph fuel pump but I have not installed it yet. The car put down 372rwhp/365rwtq SAE. Iam running consistant 12.1's at 117-118mph and just want to run as close to 11.5's (no cage needed) consistantly. The dry systems looks easier to hide.
Thanks to Nitro Dave for clearing my question up. He said they have run a car with the same setup as mine and the injectors were fine. That was using his Halo kit which is adjustable from 40-60-80hp rwhp gains.
That would put me at: 410rwhp with the 40shot
430rwhp with the 60shot
450rwhp with the 80shot
Hopefully that info will help some others out......I plan on running this kit in the near future and will update you all with the results.
Originally Posted by red fury
Hell I went ahead and ordered some 42lb/hr injectors from one on the sponsers.....Just got to get the tune for them and do the install and install the fuel pump.
Originally Posted by term
Wise choice, better safe than sorry.
