spraying gas nitrous help
How long will a 10lb bottle last spraying a 75 tnt shot?
Is there a way to see how full the bottle is w/o weighing it?
btw i read in the faq that a 125 shot will last about 9-10 full passes. But im wondering about you guys running a 75 shot.
One thing you can not put 10lbs of air into a nitrous bottle. nope not going to happen. So if you are ever told that your bottle was field with air, you know that is not right.
Ricky
http://physics.about.com/od/fermipro...tatmospher.htm
cripes man! you compress ANYTHING into a bottle under 1100 pound of pressure it will weigh.
I'm sorry, I just got served. Being a SCUBA diver, you'd think I would've thought before I spoke, but I didn't. My SCUBA tank does weigh more full (72 CF 3000 PSI) than empty.
I thought it had 2lbs in the bottle but i think the bottle actually weights more like 16-17lbs. It says it wieghts 15 but i weighed it at 17 w/ what he said was air.
No idea if he knew what he was saying or not about getting it cold...
btw is $40 average for a filled bottle?
