Fogger Nozzle Questions
My main question comes down to the different Fogger nozzles. Whats the difference between a "soft plume", a standard, and a Fogger 2 nozzle. I have my guesses but nothing concrete. Simple questions I know but I cant seem to find good answers. Thanks
Josh
Josh
Closed ex-Sponsor Account
Ok i will try I think you are talking about nos nozzles here. The first on soft plume. The nitrous discharges at 90 degrees to the fuel. this is probably nos's best nozzle. The fuel intersects the nitrous discharge at the tip of the nozzle. This nozzle and all nos ones are 1/16 npt. If you installed this nozzle into a piece of tubing straight it would blow or discharge out the end on the tube.
standard nozzle was old faithful before the fogger 2 and soft plume. It has a tube that carries the fuel to the tip but goes though the nos cavity. The tip of the nozzle has a pie cut. both fuel and nitrous slam into the pie cut making the mixure kinda of a 45 degree angle. pretty ugly of pattern I might add.
Fogger two. The nitrous discharges 90 degrees to the part. The fuel discharges like at a 45 degree roughly. Also the fuel tube goes though the nitrous cavity it requires and perfect internal seal or you could nitrous flowing back up into the fuel side causing a lean condition. The fuel comes out of the nozzle about .150-.200 above the nitrous discharge. They mix away from the nozzle. This design can allow the fuel to miss the nitrous lume and not mix properly (or to maximum).
The standard nozzle was first then came the fogger 2, soft plume and there last design was the annullar. Hope this helps.
Ricky
Ricky
Josh
Josh
