TNT Install Pictures
Not my car, I just did all the install work and wanted to answer the questions.
Black02WS6 and fredv. The stock belt tensioner was removed. The only thing the crank is spinning is the alternator. Madmark fabbed up a custom alternator mount with a turnbuckle to keep the belt tight on the alternator. I do believe the stock tensioner would be in the way if you wanted to mount the purge solenoid in that location.
That is in fact a Hawker Odessey I got it from www.gotbatteries.com. Mark also fabbed up the mounting bracket for the battery. The battery has worked very well so far.
the predetor, we plan on going with a 150 shot to start.
Thanks for all the kind works everyone. I really have to give all the credit to Mark for the install.
COME ON DYNOTUNE!!!
I'll give you a call later on, if you have the time, perhaps we'll meet up on thursday if you can make it out there.
Had a little problem with the rev limiter. It was accidentally set to 6450rpm instead of 7000rpm. We were planning on spraying till 6600rpm and shifting at 6700rpm. Instead we had to spray still 6200rpm and shift at 6300rpm.
First N/A run was 7.618@92.5mph with a 1.659 60' time.
The nitrous run results....
6.705@102.08mph with a 1.461 60' time
Not a bad gain for having to short shift it.
Even with the rev limit were it was the 150 shot netted 9 tenths, almost 10mph, and .2 better 60' over the N/A run.
I think there was a lot left on the table having to short shift it. Gonna set the rev limit back to 7000. More times to come.
P.S. The Dyno Tune Bottle heater ROCKS! Bottle pressure would dip down to the high 800's and low 900's and after turning the bottle heater on for 3 minutes pressure was back up in the 1000's.
Nice!
