Bottle leaking need help
Old Jan 8, 2005 | 05:59 PM
White98Z's Avatar
Default Bottle leaking need help
My bottle is leaking right at the top of the bottle where you screw in the hole valve assembly. How do i fix this it is on a TNT bottle. Or is it simple lossen it and put some tefflon or what?
Old Jan 8, 2005 | 06:07 PM
sleeperstyle's Avatar
you need to drain the bottle (got any ballons? haha), take out the valve. put on special pipe sealant and put it back together.
i used to work at a propane filling/ refurbishing place. i couldn't tell you the **** we used, but im sure any hardware store would have it. just tell them your propane tank is leaking and you are gonna replace the valve yourself.
propane= COLD as hell and physically similar to nitrous oxide. that **** won't leak. it also doesn't matter if you let it dry or not- i never worried about it and NEVER had a customer come back with a leaky tank (we would refurbish like 100+ tanks a day- even the HUGE *** ones).
i would not trust teflon- get the proper sealant so the bottle doesn't spring a leak when it reaches 1300 psi...
Old Jan 9, 2005 | 02:25 AM
Magic Chicken's Avatar
12 Second Truck Club
It almost sounds like you have a bad O-ring. I've replace many nitrous valves and I've never had to use teflon tape or thread sealer on my bottles, just the O-rings.
Old Jan 10, 2005 | 01:26 PM
White98Z's Avatar
SO the valve and everything screws out from the bottle and i need to replace the oring? Where do i got about getting one of these?
Old Jan 10, 2005 | 03:26 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
If nitrous is leaking around the bottom of the valve were it meets the bottle. Drain the bottle if anything is left, and unscrew the valve. The oring is bad and must be replace. We can sale you a replacement oring.
Nitrous Express, Inc. 888-463-7281
Ricky
