Bottle PSi
Old Jan 9, 2005 | 03:36 PM
Ws6O2's Avatar
Default Bottle PSi
My car went 10.76 128mph on a 100 shot with the bottle psi about 675psi If i get that psi around a 1000 psi how much more power can i make????
Old Jan 9, 2005 | 03:56 PM
Wyckedcamaro's Avatar
675? Really? I thought you werent supposed to shoot till it was around 950.
Old Jan 9, 2005 | 10:27 PM
David Tannenbaum's Avatar
Do you have a dry kit (hopefully)? If you are running wet you are REALLY lucky. I have run lower presure on mine but with a dry there is no chance of unused fuel pooling. But yes under correct bottle presure you will have significantly improved your times. I did. from a 12.5 to a 12.25. The psi under the slower time was around 700 psi. For the 12.25 I was at 800. Still alot of room for higher psi but I didn't have a bottle heater. I now do and expect to be in the 11's.
Old Jan 9, 2005 | 10:30 PM
tonyt123blue's Avatar
on my 5177 it is a night and day difference as far as torque goes.will have to wait till spring to find out about times.
Old Jan 9, 2005 | 10:35 PM
ITSTOCK's Avatar
wow, I'm surprised you could even tell that it was on. Seriously, that's damn low. I run my bottle at 1150 (most run at or above 1000). When my pressure is at around 6-700, I don't even know whether or not it's spraying. I wouldn't be surprised if you picked up 3-5mph more than you did with the pressure at 675.
Old Jan 10, 2005 | 10:59 AM
ls15244's Avatar
yeah u def. wanna keep that bottle pressure upwards of 1000 i think nx prefers 1080 with the pressure up u should notice a big difference
Old Jan 10, 2005 | 11:46 AM
Noyzee's Avatar
8 second mod
i run between 950 and 1050 depending how my car is running and how the plugs look ect. 675, my car would blow up. lol
Old Jan 10, 2005 | 09:32 PM
Green Thunder's Avatar
Like DT said hopefully you are running a dry system. What pressure are you jetted for 100 hp at? If you are running a wet system you are playing with fire. The bottle pressure plays a big part when comes to the accuracy of your system.
If you are running a wet system low pressure can equate to fuel puddling as your fuel pressure remains the same. High pressure and you can run your system lean...
If you are running a dry system its not that big of a deal unless your goal is consistency then its a big deal..
A properly jetted system running the correct (or close) bottle pressure will save you lots of headaches!
