super stealth nitrous kit?
Old Jan 11, 2005 | 02:52 PM
Nitro Dave's Nitrous Outlet's Avatar
Originally Posted by 5.8litrels1eater
Are the noids mounted somewhere in there
The solenoids are not in the intake.They mount in the cowl or behind the motor etc.
Dave
ITSTOCK's Avatar
Dave
oh
Old Jan 11, 2005 | 04:13 PM
freakynipples69's Avatar
well everyone seems to say that a 50shot is pretty much a waste for our cars so why don't i just get a 100shot jet and use that on the NX stealth kit? My only intention of a stealth nitrous kit is for the streets for emergencies only So given I wouldn't need to spray more then a few times a year, if that. So if a 1.4lb bottle can only last 1-2 100shots then I think that is perfect for me. is there any other issue that I am missing?
Old Jan 11, 2005 | 04:55 PM
ITSTOCK's Avatar
Nitrous newbies, they never learn .
J/K, kinda. Wait till you get the nitrous than tell me "a few times a year, if that" .
You don't have to, but you should consider a window switch (that kit listed already comes with a WOT switch I think). You should also change your spark plugs to a colder plug (ngk TR6's are a good plug), and it never hurts to run a higher octane, or get a tune to back timing off a little (although you should be fine with a 100 shot).
Old Jan 11, 2005 | 05:14 PM
Yes I am aware of all the needed accessories already and plan on getting a tune for the cam this spring. I'll let you all know what I decide to do. Thanks for all the help guys
Old Jan 11, 2005 | 05:18 PM
pushinfreight's Avatar
look closer....
Cant se the pics right now, can you tell me what is going on with them?
Old Jan 11, 2005 | 05:50 PM
ITSTOCK's Avatar
It is being sprayed right where you see that little shiny copper looking thing in the pic. above.
In the following pic, you can see where the noid-jet feed line goes to...
And in the following pic. you can see that the noids and feed line are BELOW the filter, BELOW the entire box, so if you take the lid off, and filter out, you still won't see a thing....
Old Jan 11, 2005 | 06:06 PM
riceyum's Avatar
I say for get about hidding it, mount you bottle on the top of your car and get a big sticker that says PROTECTED BY N20. but thats just my opinion
Old Jan 11, 2005 | 06:12 PM
thanks, that looks great. It gives me a few ideas for my setup.
Old Jan 11, 2005 | 08:23 PM
Phoenix 5.7's Avatar
if you are hiding the bottle in the spare tire area, go with a bigger bottle, i think a 10-15 will fit with a remote opener
Old Jan 11, 2005 | 09:02 PM
ITSTOCK's Avatar
definately will
Old Jan 12, 2005 | 07:54 AM
  #32
Noyzee's Avatar
8 second mod
Get a real kit,
5.8, I only use mine a couple times
a day!!!!!! lol
Old Jan 12, 2005 | 12:56 PM
  #33
RyanJ's Avatar
SSU Moderator
here's something else you can do w/ spare parts. get a 2-5lb bottle. but it in the cowl under your horn or on the drivers side under the fog lamps (may be different on the camaro's). Mount your sol's either on the firewall or more easily below your fuse boxes or headlights. No one will see them. then cleverly run a -3 line into a new hollow iat sensor into your lid. use a NOS fan nozzle w/ the end cut off, no jet. should work fine and if you cover your lines w/ that plastic wire loom...no one will see ****.
OR you could always plug a wet kit in in the back of the intake and get a fitting welded onto the back of the rail.
Old Jan 13, 2005 | 10:58 PM
  #34
Shinsetsu's Avatar
think u could do the fuel noids like that too?
but run it out the back instead of there so the maf and bellows would hide the line?
Old Jan 13, 2005 | 11:02 PM
  #35
ITSTOCK's Avatar
of course you could, you could put one set of noids on one side, and the other noid on the other, or 1 of each on the same side, maybe more than 2 will fit, I didn't take measurements (deep breathe).
That would make for one of the MUCH CLEANER wet kit installs, thats for sure.
EDIT: you don't mean running the lines inside the bellows and through the MAF, do you?? If that's what you meant, than no, don't do that . I'm sure you could hide them rather simply though by using larger diameter bellows, gromets, or tubing OVER the stock size/whatever you have. Now were getting createver
Old Jan 13, 2005 | 11:51 PM
  #36
Shinsetsu's Avatar
no under the maf not through it i know that would be bad but if i get a wet kit (i hope i will) i would want to do it that way
pop the hood and nothin to see
Old Jan 14, 2005 | 12:08 AM
  #37
ITSTOCK's Avatar
exactly Not trying to steer you away, but if you are really trying to hide it, why not just run a dry kit the same way as the one I showed?? There's even more creative place, VERY GOOD place for the switches too .
Old Jan 14, 2005 | 02:07 AM
  #38
TEA Brent's Avatar
Default polished 2.5 lb bottle
I remember seeing a picture of a dry nitrous kit that had a very very small NOS tank, about the size of an average paintball co2 tank. Anyone know what I am talking about and where I can get this, or should I just buy all the neccessary noids, lines, jets, ect and hook it up to a small tank and hide it? I wanna run a small 50-75 dry shot just for emergencies
i have a 2.5 lb.bottle with a chrome finish if interested will take 100.00
Old Jan 14, 2005 | 11:43 AM
  #39
Shinsetsu's Avatar
i would just rather go with a wet kit it just seems safer and since my car is my dd and i dont have cash to spend on a new motor i would rather go the safer route
Old Jan 14, 2005 | 12:10 PM
  #40
ITSTOCK's Avatar
Another curiosity question, why do you presume it's safer?
