Look over my wiring scematic
Old Jan 11, 2005 | 06:58 AM
Wile_E's Avatar
Default Look over my wiring schematic
I'm just trying to figure out what all goes where before I start running wires. I think I got it right but I just want you guys to go over it and make sure everything is correct.
Old Jan 11, 2005 | 07:22 AM
silverZ98's Avatar
let see here i think i see 2 things wrong that i can spot right now. i may be wrong so hopefully some one else will chim in allso.
they yellow wire on the windo switch need to be hooked up to where the ground whould be on the FPSS witch i beleave is the marked C on it
and the red wire on the window switch dont need ot be on your arm switch just run the red ot a power source like battery. but then again this may be ok all so since it will have power when switch is on.
Old Jan 11, 2005 | 07:38 AM
Wile_E's Avatar
Originally Posted by silverZ98
they yellow wire on the windo switch need to be hooked up to where the ground whould be on the FPSS witch i beleave is the marked C on it.
Then should the other connection on the FPSS still connect to the white wire on the relay?
It gets a little confusing because there is no schematic with everything on it. Everything is shown wired up seperately.
That should be okay.
Old Jan 11, 2005 | 08:00 AM
marlowchris's Avatar
Yes, Silver is correct.
The window switch just provides a ground for the relay, so the FPSS needs to be wired in series with the window switch. Also be sure to use switched ignition power for your switches. You would not want to turn off the car and forget and leave the bottle heater on.
Old Jan 11, 2005 | 08:28 AM
Wile_E's Avatar
I plan on using the power from my foglight switch since I never use them.
So this is how I should run it?
Old Jan 11, 2005 | 01:47 PM
Yup thats it. Happy wiring.
Old Jan 11, 2005 | 03:06 PM
Wile_E's Avatar
Yeah, we all know how much fun it is running wires.
Thanks for your help.
Old Jan 11, 2005 | 09:36 PM
silverZ98's Avatar
hey man send me a pm with your e-mail goign to send yo ua wiring diagram
