Windshield washer for race fuel for nitrous?Need input.
Old Jan 15, 2005 | 08:02 PM
Orange Crush 408's Avatar
Default Windshield washer for race fuel for nitrous?Need input.
I was wanting to run my race gas in the windshield washer resevoir, and put a big pump and run to my tnt F1 to try to run the 300 shot. I need all input. Please no smart *** comments. I have thought of a lot of the bad scenarios, just wanted to know if any one has tried this and if it works.TIA.
Old Jan 15, 2005 | 08:44 PM
Ben R's Avatar
Not a very good idea.
1. FLAT OUT DANGEROUS.
2. That isn't an approved fuel tank. That won't tech anywhere.
3. FLAT OUT DANGEROUS.
A 1 Gallon JAZ nitrous-enrichment tank is only about 100 bucks. A good investment.
Old Jan 15, 2005 | 08:49 PM
Thank you.
Old Jan 15, 2005 | 09:38 PM
Green Thunder's Avatar
I have a 1 gallon Jazz tank used (missing the two fittings on top) I will sell for $50 shipped to you...
But if you dont buy mine buy a new one, 100.00 isnt worth what can happen..
Old Jan 15, 2005 | 10:29 PM
cool. what pump will I need and how does it mount in there?
Old Jan 15, 2005 | 10:44 PM
STROKED's Avatar
Do you have a link to this fuel cell?
Old Jan 15, 2005 | 11:00 PM
Here is a pic
Attached Thumbnails Windshield washer for race fuel for nitrous?Need input.-mvc-752f.jpg   Windshield washer for race fuel for nitrous?Need input.-mvc-750f.jpg   Windshield washer for race fuel for nitrous?Need input.-mvc-751f.jpg
Old Jan 15, 2005 | 11:16 PM
CAT3's Avatar
Restricted User
Orange, use a holley blue pump or similar. You can find a smaller washer tank, and use the room up front to mount the jaz, or similar, and still have a washer tank. I am sure you seen Derty's setup and Recklass write up on dedicated fuel systems, you can take from those, use a lil imagination and whip up something good too. I was planning on getting a smaller fuel cell (or two) and use matching washer and race gas containers for the washer area. But still not sure yet. Make sure you research the deadhead vs. regulated return so you dont have any hiccups in the fuel system. Good luck.
Old Jan 16, 2005 | 01:04 AM
cat3, thank you.
Old Jan 16, 2005 | 05:57 AM
GHOSTRACER's Avatar
Just a note, I see that your wanting to do a 300 shot using the TNT F1. It's not going to work. The nitrous solenoid will not flow much past a 125 shot. Your going to have to upgrade to F2 solenoids (nitrous and fuel).
Old Jan 16, 2005 | 10:18 AM
69firebird's Avatar
I have a f2 kit, and was wondering is taking the fuel off of the rail that bad of an idea? I assume its fuel pressure drop is the big deal right?
how much pressure is required forthe fuel side? If I got one of these fuel cells and a pump am I going to need something huge kor will a cheap carb pressure one work?
thanks
ed
firebird455@onebox.com
Old Jan 16, 2005 | 10:38 AM
GHOSTRACER's Avatar
thanks
ed
The EFI wet kits are jetted for higher fuel pressures.
Old Jan 16, 2005 | 10:40 AM
69firebird's Avatar
thats what I was affraid of, so Id need to deliver 50+lbs of fuel pressure to the noid right?
ed
Old Jan 16, 2005 | 02:01 PM
GHOSTRACER's Avatar
ed
Old Jan 16, 2005 | 03:24 PM
GueSS Who's Avatar
I run a 300shot off of the rail. There is no lean spike for me. I do have a billy pump though.
Old Jan 16, 2005 | 06:59 PM
DopeFedZ's Avatar
Orange Crush 408- Here is one way to mount a Jaz fuel cell and Holley pump.
Old Jan 16, 2005 | 10:57 PM
Full-Force's Avatar
A friend of mine makes his own wet systems and while I have not seen what he uses for a fuel container because he always hides it inside the fender and runs a filler tube out of it into the engine compartment. For a fuel pump he uses a very cheap Purolator fuel pump from Advance Auto for 15-20 bucks.
Old Jan 17, 2005 | 04:54 AM
BottleRocket's Avatar
thats exactly how it should be. relocate the battery and put the fuel cell in its place
Old Jan 17, 2005 | 12:10 PM
thanks
