How does the MAF compensate for the dry shot?
Old Jan 31, 2005 | 08:45 PM
  #101
white2001s10's Avatar
I don't see the nozzle, or maybe it just doesn't stick up and point towards the MAF like a NOS nozzle would.
Homeslice's nozzle points so that it blasts the N2O directly on the wires.
He runs a stock non-recalibrated MAF and stock injectors.
Yes I'm sure you had to make a very significant adjustment for 60 lb injectors.
Old Jan 31, 2005 | 09:01 PM
  #102
TripleBlackRamAirT/A's Avatar
It shoots straight up about 2 inches in front of the maf, therefore under full throttle as its shooting up its getting sucked into the motor just as fast. Therefore in my theory at least, it is a perfect mist of n20 passing through the maf and giving a perfect reading to the computer. Yes I had to scale the ifr table accordingly for the injectors, but what im saying is IF the maf was maxed out it would be putting 60+ lbs an hour worth of fuel into the motor and its definately not doing that. Like I said, it maintains a perfect afr spray or not.
Old Jan 31, 2005 | 09:59 PM
  #103
ATVracr's Avatar
I dont think maxing out the MAF will also max your injectors.
It doesnt on my car, the MAF is at about 95% and the injectors are at like 75%
I have 45lb injectors.
Old Jan 31, 2005 | 10:21 PM
  #104
GrannySShifting's Avatar
It doesnt not max your injectors out. It will hold them steady at whatever pulsewidth its at, unless you fuel it more via pe table or such. maxing the maf (how everyone on ls1tech uses it) means that youve reached the upper limit of the software tables intepretation of the signal frequency relayed in Hertz
Old Jan 31, 2005 | 10:38 PM
  #105
All I'm saying is I have maintained a steady afr throughout the wide range of different shots when on or off the bottle. From 75-200 shot I have never had my afr go pig rich as is described in this thread.
Old Jan 31, 2005 | 10:53 PM
  #106
Well that's not what we were talking about to max the MAF output. It has to be liquid N2O directly contacting the wires.
When liquid N2O changes state to a gas, it absorbs a tremendous amount of energy LOCALLY as this happens. N2O in the gas state also absorbs energy, but not nearly at the same rate, and over a much wider area.
As was stated, maxing the MAF doesn't necessarily max the injectors. The final pulse-width is the result of several factors... MAF output being one one of the major factors in the load calculation. There are also several corrections applied after this calculation.
Old Jan 31, 2005 | 11:01 PM
  #107
Understood. I didnt think anyone actually sprayed directly onto the wires, it was a misunderstanding on my part. As for the injectors, I realized that shortly after i typed it, i just never fixed it. Could someone please tell me why one would spray directly onto the wires because I don't understand the rhyme or reason for doing it this way. I don't see it as the intent of it and defeats the purpose of the maf if yu ask me.
Old Jan 31, 2005 | 11:03 PM
  #108
That last sentence=what he said
Old Feb 1, 2005 | 01:36 AM
  #109
Homeslice (tm)'s Avatar
B I NGO.
My guess would be it goes to the highest load cell and sits there. Whatever the fueling situation is at that cell as influenced by the other inputs is what you get.
Old Feb 1, 2005 | 01:47 AM
  #110
Exactly!!!! Take the MAF out of the equation and as many inputs as you can to get a KNOWN fueling situation that won't change. Then pill the bottle to your desired AFR using the KNOWN fueling situation.
In normal situations the MAF makes corrections in order to strive to achieve what it determines to be the best AFR given its limited programming designed for atmospheric conditions (~20% O2). The Nitrous is 33% O2 and never makes any flow adjustments for anything. You can't make the nitrous adjust to conditions so you have to dumb down the car so it plays ball with the Nitrous.
Old Feb 1, 2005 | 07:56 AM
  #111
yeah we basically took the MAF out of the equation while spraying only.
what can I say? we're crazy
quote: "giving her all she's got!"
Old Feb 1, 2005 | 09:02 AM
  #112
I guess, but you guys are spraying 200 at 10.xx afr and I spray 200 at 12.xx afr so in theory my afr should run a little stronger. The maf on my car at least does a damn good job at fueling correctly so why trick it into running pig rich? Thats tking away performance if you ask me. Im not bashing by any means, jjust trying to understand the reasoning behind it.
Old Feb 1, 2005 | 12:51 PM
  #113
Wayne I think we should add a second nozzle/jet/solenoid like we were talking about before if keep running pump gas/drag radials
Add a .040 jet and it would be what Chuck was running should be another 60 to the wheels. Plus it may give you more time to shift to second .050 jet another 95 to the wheels, be about 10 hp to wheels less then what some of these crazy fools are spraying
Old Feb 1, 2005 | 05:45 PM
  #114
ATVracr's Avatar
Pump gas & Drag radials = 9's
As for the second part .... I aint skeerd
Old Feb 1, 2005 | 06:14 PM
  #115
Well in theory yes, but I don't run in the 10:1 afr when spraying the 200... My afr started to come up because my fuel system can't deliver anymore gas than it does. My point was that it delivers the same amount of fuel in response to a 25 shot as it would the 200 shot because of the MAF situation. The AFR will change due to the increase in O2 present as you increase the shot. Mine was still pig rich in the 10:1 range when spraying the 150. The 200 is slightly leaner than that and if I up the shot some more it will continue to lean due to the stock tune and fuel systems inability to provide any greater amount. I tune my AFR by increasing or decreasing the pill size rather than screwing with the PCM tables. My point in all this was to say that if you are interested in putting as much power as possible through your car to the ground on the bottle that my way is a cheaper, safer and more reliable way than the traditional route, even for some pretty large shots.
Old Feb 1, 2005 | 06:46 PM
  #116
Cheaper how?
It doesn't cost any less than running it the way I do, does it?
Safer how?
Running extremely rich can be just as destructive as running extremely lean.
More reliable how?
With 900+ psi aimed directly at the little filaments they could easily break. Would this not force the car into sd mode? It is the same effect as unplugging the maf, isnt it? That would be reallllyyyyy bad.
Old Feb 1, 2005 | 07:37 PM
  #117
Cheaper how?
Safer how?
More reliable how?
Cheaper: I have $400 in my setup to go 11.0 in a stock car on a stock converter with stock injectors, with a stock fuel pump, through stock mufflers. What do you have done to yours, cam, head work, converter, cut outs?
Safer: This was aimed at the wet guys primarily. If my fuel source goes **** up I don't go lean, I stall because no fuel is going in. If a wet system loses one fuel system or the other your engine goes pop fi you don't happen to cath it during the run. I was running rich, that's why I upped the shot, to lean out the AFR. Are you suggesting that you would cut fuel out so you could get by with a smaller shot? Racing isn't about going half as fast as you can.
More reliable: I always know how much fuel is going in. Do you? I run a stock MAF from 1998... don'tcha think it'd broke by now if it was going to??? Either way I know people who run everyday in SD mode with no maf. Their stuff is faster than mine.
Old Feb 1, 2005 | 08:14 PM
  #118
Ok, I have about the same in my system-400 for the n20 setup, no cam, head work, converter, cutout, etc. My car also has a raceweght of 3860lbs being a vert WS6, so I'd hope you can squeak a better time out of yours than mine being as it probably weighs 500lbs+ less.
I'm right there with you on the dry being a safer system I totally agree, hence the reason I too run a dry setup.
"I run a stock MAF from 1998... don'tcha think it'd broke by now if it was going to???"-Umm, things do break, just because it hasn't broken yet doesn't mean it wont. There is more of a chance of it breaking with 900psi of n20 spraying directly on it then there is with it being used as designed. I can spray my way the same amount as you do your way, only difference is my way is ALWAYS a decent afr. Yours only is with a unknown amount of nitrous that is yet to be found out. As for SD mode, That is how I run mine on a daily basis and that has nothing to do with what I was saying. What I was saying was-If you are spraying and it breaks the element in the maf, the car will go into sd mode. When in sd mode, It has no idea there is nitrous going into the motor which means an instant 20:1+ afr which equals-BOOM.
Old Feb 1, 2005 | 09:30 PM
  #119
I wouldnt run a 200 shot at 12:1 air fuel.
Old Feb 1, 2005 | 10:25 PM
  #120
That's what I was thinking too.
Dan
