nx heater adjustment?
Old Jan 26, 2005 | 01:58 AM
Dr.NOS's Avatar
Default nx heater adjustment?
on a full bottle my nx heater is only making 900psi...is there a way to adjust it up to 1000-1100 psi? thanks
Old Jan 26, 2005 | 07:39 AM
DERTY's Avatar
The Bull
Are you using the pressure transducer? If so, I got rid of mine and just paid attention to the bottle. That transducer would never let a bottle go above 900 PSI.
Old Jan 26, 2005 | 09:28 AM
Humanoid's Avatar
That is a good idea. I think I will get rid of mine as well.
Old Jan 26, 2005 | 11:26 AM
DynotuneN2O's Avatar
LS1TECH Sponsor
Dr. Nos,
Best bet is to replace the NX pressure switch with the Dynotune pressure switch. Our pressure switch is fully adjustable from 550psi to 1250psi.
http://www.speedshop.org/store/scrip...p?idproduct=43
Dean
Old Jan 26, 2005 | 02:32 PM
Modsquad's Avatar
10-Second Club
Mine goes up to 1050 when the car is running. It only gets it up to 950 or so from just battery power alone....are you having problems when then engine has been runing for a while or just when it sits uncranked?
Old Jan 26, 2005 | 02:37 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
I will be the guage is off just a bit. If the car runs fine and hauls *** leave it alone.
Just my 2cents.
Ricky
Old Jan 26, 2005 | 03:04 PM
Turo's Avatar
my nx heater goes up to 1050 also, no modifications to it. maybe you got a faulty heater, or your gauge is not reading properly
Old Jan 26, 2005 | 06:35 PM
LS1TECH Sponsor
Ricky might be right, A non DynoTune pressure gauge can be off by as much as 75 psi! You might want to try another gauge just in case. Im sure the place that fills your bottle might have one around? Heat it up to 900 psi then measure the pressure on another gauge. Hope you get it working well! 100psi is alot to be off.
Dan
Old Jan 26, 2005 | 06:45 PM
Brains's Avatar
Heck, I've never seen two gauges read the same yet
Old Jan 27, 2005 | 06:11 AM
LS1TECH Sponsor
Brains, I agree, they are all over the place, thats why we made an acurate one
The racers like the fact that they can see exactly what pressure they have while coming up to the line. They purge until the pressure is the same every run! Consistancy wins races....If your gauge is off by 50-75 psi thats alot!
Dan
Old Jan 31, 2005 | 04:01 AM
Dr.NOS's Avatar
thanks for the info guys...ill hook up a new gage to check accuracy....so is the nx pressure regulated heater adjustable with a set screw or something?
Old Jan 31, 2005 | 11:23 AM
LS1TECH Sponsor
D.R. nos, no the NX kit is not adjustable. The DynoTune kit is adjustable.
Dan
