nx ricky or nitro dave or anybody else
I have nx efi kit.today i opened up my bottle for just for the f--- of it.and could hear nitrious run thru the line.this is normal of course but it kept on running. some i popped the hood and could see the nitrious coming out of the purge siliniod.this has never happened before unless i hit the button to do it .the siliniod isnt wide open because i hit the purge and it fuctions properly but i think its not closing all the way to stop the nitrious from coming out. any wise guys out there to help me out? what the f--- is wrong with it?
Closed ex-Sponsor Account
Since this has never happened before there is probably trash stuck under the piston.
Now the system is not armed and the purge coil has not let the magic smoke out, it would have to trash.
Take a look at the tech tip and it described how to take a solenoid apart.
https://ls1tech.com/forums/nitrous-oxide/273116-tech-tip-nitrous-soelnoids-exploded-view.html
Ricky
Ricky
https://ls1tech.com/forums/showthread.php?t=273116
Ricky
Ricky
Sure all NX noids can be sent in. The other thread was just showing people how to service the parts if they wanted to... You can pull the noid off and send it to me. All your will pay is the frieght.
The tool is 10.00
Ricky
The tool is 10.00
Ricky
Alright I check out your thread just before this thread was written.How much is that tool that you say is needed.And is it really nessasary for me to have?Im no nitrious mech. this would be the only time I would use it.
Please make it attention warrany department, and give all your return information.
Thanks,
Ricky
You can send the noid into NX and we can take care of it for you. All you will to pay for is the freight. The tool is not neccessary it is just out there if people want it.
Thanks,
Ricky
Thanks,
Ricky
I had this same purge noid sticking open thing. I first noticed when useing n2o I had weak hit. To make a long story short. When I was washing car water would run down purge line and collect at noid. After a while it became gunked up and/or slightly rusty. I just cleaned it up and put it back together and everything is fine. When washing now, I tape my bull nostril purge, pointed up and over windshield.
