its almost time for..
Old Feb 15, 2005 | 09:34 PM
stevensLS1's Avatar
Default its almost time for..
me to start purchasing my nitrous setup. this is what i have decided on.
nx wet kit. with xl upgrade (from cold fusion). dual purge bottle heater, and bottle opener. i plan on trying to spray between 150-200 shot. ive got tr-6's which i will gap to .38. anything else?
Old Feb 15, 2005 | 10:50 PM
CAT3's Avatar
Restricted User
whats the xl upgrade from CF? The purge, heater & opener.
Old Feb 15, 2005 | 10:56 PM
Poik's Avatar
Probably going to want to gap lower than .038 with 150-200 shot.
Old Feb 15, 2005 | 11:35 PM
stevensLS1's Avatar
how much lower would u say?
the 2nd one down is the upgrade kit! tell me what yall think
Old Feb 16, 2005 | 12:02 AM
CAT3's Avatar
Restricted User
ok, seen it now. sorry hadnt looked at their site in ages. Me personally, I dont think you will need that upgrade kit at all. No reason for it until you are running nitrous for a while, forged internals, ready drivetrain etc.. The basic NX wet kit will put more than enough power out to blow your bottom, trans and rear if not used right, tuned etc. The bottle heater, opener and a single purge are nice, but would also look into a blowoff valve and tube if you get teched at the track.
TR6 gapped at .038 is wide for 150, I would close them down to .034 min, and work from there. I normally run mine at .032, street or track using a 150-175 shot.
Have fun, be safe.
Charlie
Old Feb 16, 2005 | 07:30 PM
stevensLS1's Avatar
so ill be fine on my stock fuel sys correct? if not besides the 255 walhbro pump what kinda/ size injectors should i get? thanks a million!
Old Feb 17, 2005 | 05:19 PM
stevensLS1's Avatar
anyone about the fuel sys?
Old Feb 18, 2005 | 09:10 AM
X-MUSTANG OWNER's Avatar
I own a 2002 SS and have run the nx wet system for 2 years. Long story but you should read and check your original plug gap for stock. When I put the 150 shot on my car I set the gap for the tr-6s to 38 and tested it ran fine till it warmed up had a miss that got worse and worse for 15 min. till I got home. let it cool off over night. Killed me to know what was wrong. Next morning checked the wires, all fine then tested it again, ran fine till it warmed up, then ran soo bad that when I got home I couldn't get it all the way up the ramps. Worried I messed something up, I called a friend that works for a big Chevy dealer for 20 years. He works on all the Eletronics for the dealer, many service awards. Told him what I did and what was happening and he asked why I didn't ust the original plugs (Champion plugs) I said that everybody I talked to said to use the tr-6s and gap @ 38. He checked the gap from the factory and said the factory has the champion plug set @ 60 and that my car has one of the most stout eletronic systems on the market. (I noticed the big gap difference from the 38 to the 60 and thought it was different, but!!!) He said to gap the Champion plugs from 45-50 and I should be just fine. Has worked just fine for 2 years now. He has a personal vett with the LS1 and runs in the low 10s he was right.
