Low Compression engine and N2O questions..
Old Feb 22, 2005 | 06:26 PM
frcefed98's Avatar
Default Low Compression engine and N2O questions..
Might be going one of two routes here shortly as I might be getting rid of the ATI S/C set up.
One route is strictly N2O.
How would my 9.1-1 compression 348 like the gas?
I'm thinking 175-250 shot, direct port set up.
My current cam is a 233/244 .578/.602 on a 115 LSA
Rest of the mods minus the S/C kit will be run with the N2O.
I have plenty of fuel so i'm not worried about that. 60lb injectors, Racetronix Plug and play set up and high flow lines and rails with ADJ FPR.
Thanks for any help or advice you can shoot my way.
J
Old Feb 22, 2005 | 06:44 PM
hellbents10's Avatar
LS1Tech Sponsor
The cam will work great on the juice, and you will ahve less timing and kr issues with that compression. Might want to drop injector size if getting arid of the ATI. Unless you want to go big on a dry shot. Bottom line is that the thing will still be way fast.
Old Feb 22, 2005 | 06:56 PM
frcefed98's Avatar
Just what I want to hear, gotta be able to click off a better time than my current set up which I won't think will be too hard for a N2O combo. This is looking a lot better than the FI route but the decision is still a hard one. I'm addicted to boost bad. I can swap injectors with my bro he has 42.5's, he ought to need 60's soon with his t-trim powered 396 LT1.
Which direct port kit is looking good these days?
J
Old Feb 22, 2005 | 10:10 PM
RyanJ's Avatar
SSU Moderator
two stage would be a good option if you still have that tnt kit
personally, id like some nxl injector cups/nozzles; and some custom built lines. with the cash from the s/c you could do a nice sep. fuel system and the dp above. just keep jetting up till you get 10's.
Old Feb 23, 2005 | 05:28 PM
frcefed98's Avatar
Hi Ryan,
TNT kit is long gone, it's pulling duty on a 454 big block dually and doing very well
I have a D.I.Y wet kit right now, but i'm thinking direct port with a LSX manifold and progressive controller to bring it in. 175-200 should get me a ten pass with what I have now pretty easily. Damn S/C has net me a 11.18@124.96 at our mile high altitude
Old Feb 24, 2005 | 01:26 AM
Sam88Gta's Avatar
Like this?
I have a few more pics of it if you want to see more.
Old Feb 24, 2005 | 06:43 AM
dug's Avatar
dug
Do you guys think there is any benefit with running 6.0L heads on a stock motor to drop compression? I am thinking about spraying a 250hp dry shot on the stock shortblock. Would lowering the compression help it live?
Old Feb 24, 2005 | 07:34 AM
Z284U2TRY's Avatar
Originally Posted by Sam88Gta
Like this?
That is a 2 stage in the pic? How does the 2nd stage enter the engine I see the direct port at the injector bung. Why are you running 2 fpr's? How is your fuel system set up and how much are you spraying? Setting up now to spray a 300.
Old Feb 24, 2005 | 10:49 AM
RyanJ's Avatar
SSU Moderator
yep...just like that. What solenoids are those? Post some more pics.
Looks like one FPR for engine, one for nitrous (separate system, or at least a different pressure than on motor). Oh, and i don't see a second stage.
Also, low compression is not necessarily bad, but I would prefer a higher CR on nitrous. The crappy part of the stock motor is not 10.1:1 CR, its hypereutectic pistons. Spend money on pistons, not heads.
Old Feb 24, 2005 | 11:14 AM
dug's Avatar
dug
Yeah, I know the stock pistons are the weak link. Heads are easier to swap than pistons.
Old Feb 24, 2005 | 03:38 PM
Sam88Gta's Avatar
The big nitrous solenoid is a NX 1000 horse.The fuel solenoids are NX also one mounted to each rail.
You are correct,one regulator is for the motor and one for the nitrous system.There are two totally seprate systems running two 255 pumps in the stock tank.
I didnt get any pics of the pump setup before it went into the car but i have some from the bottom side that will give you some idea.
Old Feb 24, 2005 | 06:17 PM
69firebird's Avatar
thats a nice setup sam, over kill for most but looks damn sweet
Old Feb 24, 2005 | 06:20 PM
frcefed98's Avatar
Very NICE! Thats what i'd be shooting for if I go this route.
J
Old Feb 25, 2005 | 02:32 AM
Sam88Gta's Avatar
The whole damn car is over kill.
Its a cam only car with a th400...Neal Chance converter to a Mosier 12 bolt.The fuel system is WAY too much for the car also(only makes 410rwhp on motor).Thats the way to do things if you want to drive a car everyday and run very fast at the track...then drive it back home.
The nitrous system was build cause the past wet/dry combo didnt fair too well with #7 and #8 cylinders spraying through the throttlebody.Its only pilled at 180 at the moment and will never go past a 250.
Old Feb 25, 2005 | 05:11 PM
69firebird's Avatar
how much would it cost to have you do that to my intake sam??
PM me a number
thanks
ed
