Bottle Mounting
Old Mar 13, 2005 | 02:03 PM
zrated's Avatar
Default Bottle Mounting
Hey guys this is my first post on LS1Tech.com I am buying a dynotune kit soon for my 98 z28 and I was wondering if there was any pics or advice on mounting my bottle. I want to mount it in the hatch right behing the seat, the bottle will be a 10lb bottle. Any help well appriciated Thanks Chris
Old Mar 13, 2005 | 02:12 PM
nspr8td lt1's Avatar
i used a piece of wood to mount my bottle brackets, everything fit perfectly inside the spare tire well. looks bone stock with the cover on.
Old Mar 14, 2005 | 12:31 PM
HAMRHEAD's Avatar
I got mine on the hump between the rear seats. If you do a search on this topic you should get a lot of posts with pics of the install. Good luck!
Old Mar 14, 2005 | 01:09 PM
john3daly's Avatar
When the seats are up, you can't see the wires as much. Be careful, the gas tank is right below where you'll be drilling.
Old Mar 14, 2005 | 09:04 PM
zrated's Avatar
What precautions should be takin and any pointers on how to install my bottle where I want too I was thinking of cutting a 16gauge piece of steal mounting the bottle to that then mount that to the trunk??? The wires where do the go to couldnt u run that under the carpet and same with the nitrous line>>>???
Old Mar 15, 2005 | 03:32 AM
Gold Z's Avatar
I have my bottle mounted in the same position you are talking about and it works fine.
Old Mar 15, 2005 | 09:52 AM
Mr_Bond's Avatar
Spare tire spot works good
Old Mar 15, 2005 | 10:26 AM
zrated's Avatar
GoldZ I want to mount my bottle like that, I was wondering if I could cut my blow down tube right at the carpet then hook fuel line or a strong rubber house to the blow down tube and route it under my carpet to my spare tire well out of the car or how would I go about routing my blow down tube???
Old Mar 16, 2005 | 01:54 AM
Gold Z's Avatar
I'm sure you could make that work. Just use large diameter high pressure tubing.
