Launching with big convertor?
IMO it is almost impossible to get the max out of the car if you are trying to hold the gas at 3/4 or 90%. With the 2-step set-up you can slam it to the floor and leave on the entire shot.
And how can a timing tuner - based on RPM's stop nitrous from engaging when I want to leave off my converter and transbrake at say 4200rmps????
David
you got a street car, don't worry about transbreak...
Yust give it foot throtle tp stage it to 3800-4000 and then cut it loose on the bottle...if it spins, try the same technique at 3500 rpm (flashing the converter with the nitrous) and keep going down to about 2500 just to see how the car reacts and launches, as well as seeing if it drive through th econverter on the nitrous.
sdb
