TNT 150 wet on my set up.....1/4 mile guesses.
Originally Posted by WOT
low 10's...
Also the AFR 225 heads and a cam upgrade to a 248/252 113 lsa. from my current 242/242 .610/.610 114 lsa.
Depending on my cash it'll be the TNT 150 wet or all the goodies listed here.
BTW, are you spraying a 150 shot?
Originally Posted by theblur98ss
What do you run NA? What tires and suspension? Running a quick ET is alot tougher then just making the power.
The tires for the run at the track would be slicks.
I would say low 10's maybe high 9's. I would probably change the cam out though, I would have thought that you would been over 500 rwhp NA with a hoss of motor like you have.
There's got to be 25-30hp in an 85mm MAF, ported LS6 heads and a new tune. RIGHT???
If I go with the FAST 90mm intake and 90mm TB, AFR 225 heads and a new 248/252 .610/.610 113 lsa cam, I should get around 40hp total. Maybe 520 RWHP through an A4 tranny would be pretty good, right?
