How many passes on a 150 shot?
Old May 19, 2005 | 02:23 PM
BFate's Avatar
Question How many passes on a 150 shot?
How many quarter mile passes will I get out of one 10lb bottle on a 150 NX wet single nozzle kit?
Old May 19, 2005 | 02:34 PM
ATVracr's Avatar
I only make 3 passes on mine.
I think on the 4th you'd run out 1/2 way down the track.
Old May 19, 2005 | 02:42 PM
Nitro Dave's Nitrous Outlet's Avatar
Depends.I have gotton 6 and 7 quarter mile passes out of a 10lb bottle.
Dave
Old May 19, 2005 | 02:47 PM
foxspy's Avatar
I did 2 100hp shots and 3 150hp shots on the 1/8th mile and used 5lbs.
Old May 19, 2005 | 03:45 PM
ATVracr's Avatar
Dave
Really?
What does it depend on?
Old May 19, 2005 | 04:10 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
The amount you will use depends on how long your system is on. How many times you purge, the size of the purge solenoid, what hp level you are at, progressive system or not.
Quick math says you will use 1lb for every 100hp for 10 seconds. So if you used 150hp and your car runs 10sec. 1/4 mile time you use 1.5 lbs of nitrous.200hp the same times you used 2lb.
Now once a bottle gets below its half way point the performance will start to fall off at the 150 setting.
Ricky
Old May 19, 2005 | 04:17 PM
DopdBrd's Avatar
AH HA, so thats y my car hit soo much harder when I filled the bottle, it was out of go juice!!!!!!! I ran like 4-5 100 shots and 3-4 150 and couldn't figure out y the 150 didn't feel that strong. stupid me
Old May 20, 2005 | 10:59 AM
BFate's Avatar
Thanks guys that's what I was looking for. Guess I better get it right at the track when I go for the first time with the N20 I'm betting 4-5 passes on my current setup.
Old May 20, 2005 | 12:10 PM
TRYTHSS's Avatar
i usually run 4 times, when i go to the track, and it is about 5 lbs., so i am guessing i could get 8 out of it but you never want to run it all of the way empty
