Nitrous V.S. Supercharger
Plus, I think the stock bottom handles juice better than the blower, especially if you crank up boost.
LOL just messin I think what would solve the problem would be nitrous+blower
But remember nitrous effectively doubles with FI.
Listed below are the reasons I went with a NX system:
1) Inexpensive.
2) Does not add so much weight to the front of the vehicle.
3) The weight it does add is usually in the rear where you want it.
4) 75 horsepower one minute, 200 the next etc... (flexible)
5) Massive torque down low unmatched by any other power adder even roots.
6) On a hot day FI car is off 3 to 5 tenths, an N2O car 1 to 2 tenths.
7) No intercooler heat soak. (No long waiting periods required.)
8) Stealth (hidden) if need be. (see money racing)
9) Can remove it and reinstall in any internal combustion vehicle you own. (Try that with your F1R or Twin Turbo set up.)
10) Does not transmit damaging harmonics to your crankshaft. (SC)
11) Does not create intense heat under the hood. (hard on plastics, rubber, paint, etc)
12) Wear and tear only when you need the hit, not taxing the motor all the time.
13) You can race NA in the brackets for consistency, then shoot it for a heads up race or the occasional kill.
14) Intimidation factor, (hitting the purge when opponent is lighting the second bulb staging.) Priceless!
Yes, as we all know there are a few drawbacks, but I feel the pro's heavily out weigh the con's.
Nitrous will damage the engine alot quicker than FI.
FI is progressive power. Nitrous is an instant hit of power.
I have done both. If you have the money. FI all the way. Power on demand. So nice getting into boost at part-throttle merging on the freeway.
