Question about n2o critical pressure
I have a question regarding how gasses work (in regards to n2o). From what I understand, at room temperature nitrous's vapor pressure is about 700 PSI, and at 95 degrees around 1050 PSI.
I've read that it's critical pressure is 1069 PSI @ 97.7F (http://en.wikipedia.org/wiki/N2o - The units are in metric but you can trust me on the conversion).
I have a question regarding this behavior in a nitrogen push configuration.
The definition of critical temperature appears to be the temperature at which it becomes a gas, and you cant get it to be a liquid no matter what pressure you make it.
The definition of critical pressure, is it's the vapo rpressure at the critical temperature.
The critical pressure is 1069 PSI. Does this mean that if I keep the bottle below 97.7F, I can push the N2O at higher pressures like 1100 PSI, or does this mean when you exceed 1069 PSI it becomes a liquid anyhow?
That's the way I read it, anyway. But, I'm no chemist. Personally, I would be interested in a Nitrous push system. If N2O is always a gas over 97.7 degF, then what would be the feasibility of having a small bottle of N2O, heated to 110degF or so, and using that as your "push" agent? It'd pass tech, where N2 push wouldn't.
-Mark
