Nitrous with 11 or 11.5:1 compression?
Old Jul 29, 2005 | 09:00 AM
RollinSScamaro's Avatar
Default Nitrous with 11 or 11.5:1 compression?
I am putting some new heads on this weekend and they are the TEA stage 2 5.3's with 62 cc chambers.. should put me around 11 or 11.5:1 compression.. I was just wondering for in the long run.. what would be a safe shot to run on my car? Would a wet kit be alright spraying a 50-100 shot? I don't wanna be to hard on my stock bottom end.. Anyone spraying with a similar set up?
I'm not looking to spray a lot.. just a safe shot to gain a little mroe power when i need it
Thanks
Old Jul 29, 2005 | 10:38 AM
NXZ28's Avatar
Put some NGK TR6 plugs in it. Buy the Timing Tuner from Tbyrne. It is a plug and play system so you can retart the timing. I would pull 2-4 degrees back for the 100 shot. Run 100 octane gas in it to be on the safe side.
Old Jul 29, 2005 | 01:33 PM
Alright cool... would stock GM head gaskets hold the 11.5 compression with a 50-100 shot of nitrous with a timing tuner, TR6's, and 100 octane gas? or would i definately need some aftermarket stronger head gaskets?
I'd still of course buy all of the safety equipment for the kit.. like the Fuel pressure safety switch and a new intank pump..
I'll definately throw one on over winter as long as the GM head gaskets can hold all of that pressure? Let me know! Thanks
Old Jul 29, 2005 | 02:02 PM
Race Car Driver's Avatar
11 & 7 Second Clubs
I'm spraying a 150 dry shot thru my 11.5:1 346 cid motor, with 205s and max spark advance at 22 degrees.
Old Jul 29, 2005 | 02:07 PM
VINCE's Avatar
Shorty Director
I dont see any problems with spraying it. I do it..
Old Jul 29, 2005 | 02:24 PM
awesome! i'm probabaly going to save for it over winter and have it on for spring so i can shoot for a 10 sec time slip..
The only concern was having the stock GM head gaskets on and not some $90 a piece aftermarket gaskets.. Is that not a big deal? Thanks for the replies!
Old Jul 29, 2005 | 03:37 PM
Gimp98TNT's Avatar
I would just stick with the stock GM MLS gasket. I made 648rwhp 700rwtq with no issues useing those gaskets. I also used ARP head studs im sure that makes a differance. That was a 225shot btw, on a stock bottom end.
Old Jul 29, 2005 | 08:45 PM
BLK02WS6's Avatar
Mine is pushing 11:1 and I spray 100 shot TNT on pump gas all the time. I run 24* of timing and TR-6 plugs. And I also have GM MLS head gaskets. You'll be fine as long as your tune is on and your fuel system is up to the whole packages needs.
Old Jul 30, 2005 | 09:07 AM
haha geez those stock bottom ends hold alot more than what i thought.. some people spraying over 200 shots doesn't make me feel to bad about a 100 shot now haha.. Thanks for the responses!
