How much timing do you run on 200+ shot?
Old 08-03-2005, 05:53 PM
badls1's Avatar
Default How much timing do you run on 200+ shot?
I was curious as too what you run for timing on 200 + nitrous?
What is your fuel octane?
What is your timing?
How much nitrous (shot)?
Thanks in advance
Old 08-03-2005, 11:02 PM
Restricted User
CAT3's Avatar
116 leaded, 26*, 220 NXL Shot.
101/93 50% mix 24*, 175 Wet Shot.
I had my NA timing up at 33* w/o KR for the longest time, then began lowering it as the extra 5* didnt net me any gains, so safer to be lower.
Old 08-04-2005, 01:48 AM
Robert56's Avatar
22*
92 octane
on a
175, 185 and 200 shot and no KR, so far.
Robert
Old 08-04-2005, 06:30 AM
GM Muscle's Avatar
24* with a 93/104 mix, about a 225 shot at the crank.
Cat, what are you running for O2 sensors with the 116? Also, where you using TR-6s and how do they like the 116? Seems like they would foul running N/A.
Old 08-04-2005, 07:48 AM
necrocannibal's Avatar
Im running a 225 shot with 25* timing. I am using a stand alone fuel system for the nitrous with 116 octane in it. No KR or any problems yet.
Old 08-04-2005, 11:50 AM
badls1's Avatar
on my setup i am only seeing 22* on straight 105 octane on 200 shot. curious to know if i will pick up et if i run higher timming.
Old 08-04-2005, 12:17 PM
O'dell's Avatar
How much timing would you all recommend for a 150 wetshot (TNT) on Pump Gas?
Old 08-04-2005, 12:29 PM
badls1's Avatar
150 shot and pump gas probably around 20*. remember that 150 is rwhp. Its like 195 flywheel.
Old 08-04-2005, 12:33 PM
O'dell's Avatar
Yeah I realize that, that's why I stated it's a wet tnt shot. I have access to race gas (55 gallon drum in garage right now actually), and will more than likely use a race gas/pump gas mix on the 150 shot just for safety since it's still stock block, was just curious.
Old 08-04-2005, 12:42 PM
badls1's Avatar
well i have the same setup as you do on 200 shot straigt f&l 105 and cant run more than 22*. but then again every car is diffrent. mix them toghter half and half. change your knock retard from 4* to 8* (to be on safe side) run 25* timming and see what happens.
Old 08-04-2005, 01:20 PM
Robert56's Avatar
Normally on a 150hp shot and lower no timing needs to be pulled on a stockish car. Should log to be sure.
Old 08-04-2005, 01:45 PM
O'dell's Avatar
Well I have Heads/Cam/ and all the bolt-ons, plus it's an auto . The heads aren't milled, but they are CNC ls6 heads.
Old 08-04-2005, 02:58 PM
GM Muscle's Avatar
I think 20* is way to low unless you only run 91 octane. or something. For a TNT 150 shot I run 24* on straight 93 octane. I've never had a problem with detonation. At 26* I would start to pick up 1-2* of random KR.
Old 08-05-2005, 12:15 AM
calongo_SS's Avatar
I agree. I run 22 down low, and 24 up top on a TNT 150 shot. I consider this to be a very safe tune. My tuner said I'd probably be fine w/ 26 if I wanted to push it.
Old 08-05-2005, 07:08 AM
v8maro's Avatar
Harry, how is it going?
Remember the F4 kit you sold me? Check the pic below for what that intake looks like now
Anyhoo, did you ever find the relays for the kit?
thanks
-Steve
Old 08-05-2005, 12:22 PM
badls1's Avatar
thanks
-Steve
I think i seen one of them. they are 30amp realys like $3 each you could get them from any auto parts store.
That manifold looks nice. I missed my old combo. nothing comes close to it. since the turbo is taking some time, i am running my friends tnt f2 kit.
did you get times out of your set-up yet?
harry
Old 08-05-2005, 02:43 PM
v8maro's Avatar
harry
No, I got screwed out of my motor =\ I am still building it so it's taking a while. I didn't know the relays were that cheap, heh. Also, you had the F4 jetted for 200 when you shipped it right?
-Steve
Old 08-05-2005, 03:34 PM
badls1's Avatar
i belive it was 225 check the jet size or let me know the jet size and i ll get you the hp rating.
Old 08-08-2005, 01:56 AM
strokedls1's Avatar
I get bosch relays for 2 dollars a pop. That kit was jetted for 225 shot. I would switch it to a high pressure inline bosch pump. The low pressure pump has too much variation especially at altitude. You would also need to swap to a high pressure regulator. It will make it much easier to tune. Money well spent imo. A lot of time went into making that f4 kit.
Old 08-08-2005, 02:25 AM
Mr Powell's Avatar
I spray 400 with 21 degrees of timing. 11.5:1 compression motor. C16 in the Nitrous Fuel Cell and 114octane in the normal tank..
o2s love them!! I also run a NGK Power-8 Plug gapped at .28
Quick Reply: How much timing do you run on 200+ shot?
