Nitrous with supercharger?
Old Aug 15, 2005 | 02:42 PM
02' hawk's Avatar
Default Nitrous with supercharger?
Can you run a dry shot of nitrous with a D1SC supercharger? I already have the NOS-5177 kit for the ls1 in my other car. I want to put it on my new 02' T/A with the supercharger. What all would i need to do this right? Could i put the spray nozzles in the metal air box or will the supercharger mess them up? I thought i saw a plate that goes in front of the mass air flow sensor for nitrous.
Old Aug 15, 2005 | 03:17 PM
Race Car Driver's Avatar
11 & 7 Second Clubs
Absolutely. I put a 100 dry shot and SQ Trim on an LPE, 10:1, heads/cam, 346 and ran 10.30 in vegas at 3000 ft. It would have run 9s at sea level.
Old Aug 15, 2005 | 04:15 PM
860 Performance's Avatar
I run a wet shot (100hp) and a dry shot (200hp) with a supercharger.
10.07 @ 139 is my best so far on pump gas & DOT's.
Since you are far from a stock set-up, I would recomend a single fogger wet system because its easy to tune, (just change jets).
Unless you have a custom ECU with a nitrous funtion, then dry systems are super easy.
Bickel, how do you get the fuel for your dry shot?
Old Aug 15, 2005 | 04:18 PM
TRANSAMWS6-98's Avatar
It wont blow up? Even if the bottom end is stock? Damn!
Old Aug 15, 2005 | 05:30 PM
11 & 7 Second Clubs
8 lbs of boost and a 100 shot should be around 600 rwhp.
Old Aug 15, 2005 | 05:57 PM
02' hawk's Avatar
The bottom end i was told that is not stock. Where should i put my spray nozzles?
Old Aug 15, 2005 | 06:56 PM
I personally would not spray if you are not sure if the bottom end is built. I have seen alot of cars come to an end when they mix Nitrous and a Supercharger with a stock bottom end.
Old Aug 15, 2005 | 07:21 PM
v8juice's Avatar
I am running an ATI with 7 lb of boost and 125 hp single fogger shot of nitrous in front of the throttle body on a stock bottom end.So far so good.
Old Aug 15, 2005 | 09:19 PM
02' hawk's Avatar
Are you using a plate or is it directly in the metal air box?
Old Aug 16, 2005 | 04:31 PM
v8juice's Avatar
between the MAF and throttle body
Old Dec 2, 2005 | 07:46 PM
02' hawk's Avatar
Thanks.
