NX TPAS + MSD + FPSS - will this work?
Old Aug 21, 2005 | 10:33 AM
Warp6's Avatar
Default NX TPAS + MSD + FPSS - will this work?
Should I wire the TPAS as directed here then run the GREEN wire (#87) to the RED wire in relay number 1 of this diagram Thanks for all the help! I need it!!
Old Aug 21, 2005 | 05:45 PM
Warp6's Avatar
to the top
Old Aug 21, 2005 | 06:14 PM
Robert56's Avatar
What a complicated mess, imo. Never used one and probably never will. Talk to the NX guys. I use a micro sw under the pedal. Much simpler and more durable and a cleaner look in my opinion. Why NX dosen't put the numbers on their relays is behond me. Oh, and the micro sw is only a couple dollars. The cars computer allready has a built in tps.
Robert
Old Aug 22, 2005 | 08:58 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
Hope this helps..
Ricky
Old Aug 22, 2005 | 12:30 PM
Robert56's Avatar
Ricky, now that's a nice easy to follow wiring diagram. You should do all of their schematics in the install instructions.
Robert
Old Aug 22, 2005 | 04:01 PM
Warp6's Avatar
Originally Posted by NXRICKY
Hope this helps..
Ricky
Ricky, that is great! Also spoke to Josh at NX today. He described your diagram to me. This should be in your manual or at least in a wiring sticky here. AWESOME!! Great site here, great bunch of guys!! I'd buy you and Josh a beer (or twelve) if you were nearby!
Old Aug 22, 2005 | 04:08 PM
NXRICKY's Avatar
Send in the mail a coupon for some, I am sure Josh it.
Ricky
Old Aug 22, 2005 | 04:45 PM
Warp6's Avatar
Ricky
You must have already been in it!! Say again...
Old Aug 22, 2005 | 06:00 PM
Warp6's Avatar
RICKY, do you have that schematic with an MSD window switch? I'm thinking instead of grounding the FPSS I will run it to the YELLOW on the MSD. Does that sound right to you? Thanks again! Craig
Old Aug 23, 2005 | 08:44 AM
NXRICKY's Avatar
Yep your correct connect the yellow wire to the fpss and then it will find ground though the window switch.
Ricky
