125 Shot Dry?
Old Aug 25, 2005 | 09:34 AM
ehirst83's Avatar
Default 125 Shot Dry?
I'm almost done with my 5177 kit and am wondering what kind of shot I can run on stock fuel system. I have the NGK TR6 plugs and mods in my sig. Can I run the 125 shot or should I stick with just the 100 shot?
Old Aug 25, 2005 | 10:06 AM
DD966's Avatar
125 shot here. Stock fuel system. It's all good.
Old Aug 25, 2005 | 10:17 AM
ehirst83's Avatar
Are you still running stock fuel pump?
Old Aug 25, 2005 | 04:09 PM
cantdrv65's Avatar
Post
You could even spray more than that and be fine pump wise.... You'll have to ask Robert on what will max out the injectors however.
Old Aug 25, 2005 | 08:12 PM
Robert56's Avatar
You should be fine, as 125 NOS is about 106 rwhp and many guys are running this on stock fuel systems. Can't remember for sure, do you have the 28lb injectors?
Robert
Old Aug 25, 2005 | 09:28 PM
nostyta's Avatar
I was running a 125 dry shot on my stock pump and stock 26 lb injectors, no problems. I'm pretty sure that the 2000 models all had the 26lb injectors or at least mine did.
Old Aug 26, 2005 | 11:21 AM
1320Kid's Avatar
99 and 00 came with the 26lb injectors.
Old Aug 28, 2005 | 03:42 AM
X-ZZ4's Avatar
You can pick up nearly new 28lb injectors really cheap.......lotsa guys upgrade quickly. I got a set out of a Z06 with only 2000 miles on them for $50. Money well spent IMO, especially if you're going to a 125 shot......
Old Aug 28, 2005 | 12:06 PM
Robert56's Avatar
There's a link in my Web for Ford SVT 30lbs (36 at our pressure) for 185 or so. Will give room to grow.
Robert
Old Aug 28, 2005 | 02:41 PM
B-MAN's Avatar
Sweet!!!!!!!!!!!!!!!!!!!!!!!!!!
