which jets?
Old Sep 2, 2005 | 10:56 AM
dubrado's Avatar
Default which jets?
Which jets do I need to use for a 100 wet shot?
Old Sep 2, 2005 | 11:04 AM
NOSjohn's Avatar
Restricted User
What kit ? Usually, depending on the kit, a .047 Nitrous and .025 Fuel will get you there. I would give a quick call to your kit manufacturer just to be safe.
Old Sep 2, 2005 | 11:22 AM
dubrado's Avatar
i'm parting together a kit.
Old Sep 2, 2005 | 11:39 AM
NOSjohn's Avatar
Restricted User
For the GTO? Those are the average recommended sizes for a safe tune on an LS1/2/6 with at least 50psi of fuel pressure. Some people also run stock timing but you may want to consider taking out 2 degrees for the nitrous.
Old Sep 2, 2005 | 12:10 PM
dubrado's Avatar
I was running 21* stock, I'm at 24* now....I think i'll have them put it back to stock just in case
thanks for your help
Old Sep 2, 2005 | 12:31 PM
NOSjohn's Avatar
Restricted User
Correct or close to stock - ~ 22*. Then, if you don't have knock, bump it up 2*. You're welcome.
Old Sep 4, 2005 | 01:20 AM
BIRDONNOS's Avatar
Default nitrous
here ya go
Old Sep 4, 2005 | 01:23 AM
dubrado's Avatar
Originally Posted by BIRDONNOS
here ya go
thanks, that is really helpful!
