Is a purge really neccessary?
Old Sep 8, 2005 | 09:49 PM
Okie02's Avatar
Default Is a purge really neccessary?
i was just wanderin if a purge is really neccessary..is it something you have to have? thanks!
Old Sep 8, 2005 | 09:58 PM
iamsickofitall's Avatar
no, it just ensures that nitrous is sitting right at the solenoid and there is no air trapped in the line - if you're counting every hundredth of a second in the 1/4, then you should have one - i personally can't really tell too much of a difference from when i purge and when i don't purge - then again, i don't have timeslips without purging to back this either
Old Sep 8, 2005 | 10:07 PM
Okie02's Avatar
ok thanks..so would any one reccomend/not reccomend, getting one?
Old Sep 8, 2005 | 10:35 PM
jmac_98ls1's Avatar
get one, they are cheap, dont hurt to have since they do make sure that u have a fresh stream of nitrous at the motor. plus they look hella cool
Old Sep 8, 2005 | 10:47 PM
white2001s10's Avatar
I recommend not getting a purge. It is completely unneccessary and many think it looks rediculous.
It is very easy to purge any system without any of the extra "purge" equipment. That stuff is just for show.
Old Sep 8, 2005 | 11:00 PM
Matt@HSW's Avatar
My vote would be to get one. While you don't NEED one, they are handy for purging the line and getting all the nitrous out of the main feed line when you close your bottle valve.
Matt
Old Sep 9, 2005 | 01:14 AM
Drew778's Avatar
Matt
That takes the fun out of the ride home
Old Sep 9, 2005 | 10:13 AM
Nitro Dave's Nitrous Outlet's Avatar
The purge serves two other puposes that just making a cool show.
First you use it to purge the air out of your nitrous line.This will give you a better hit and inmprove your 60 ffoot time.
Second.
It is used to bleed down bottle pressure.If you turn your system on and you have to much bottle pressure you can purge it down.
Dave
Old Sep 9, 2005 | 01:17 PM
Okie02's Avatar
ok thanks for all the input..i think im gonaa go ahead and get one..
