New LS1/LT1 plate systems!!!
Old Sep 19, 2005 | 02:56 PM
Brains's Avatar
It'll clear But the lines will be kinda tight fit. You can also use 90 degree fittings that will clear with ample room to spare.
Old Sep 19, 2005 | 03:02 PM
Nitro Dave's Nitrous Outlet's Avatar
Thanks Brian.I was not sure.
Dave
Old Sep 20, 2005 | 12:38 PM
bodydropped's Avatar
could you try a 45 angle instead of a 90.i don't think it would be very good for flow if it 90s twice right before it is sprayed.imo.
Old Sep 20, 2005 | 12:46 PM
Brains's Avatar
Yeah a 45 would be fine too. It actually fits without an angle at all, but the line on the pass. side sits right up against the EGR tube.
Old Sep 20, 2005 | 12:52 PM
i don't have egr but i was just throwing that out there
Old Sep 21, 2005 | 04:29 PM
black_z's Avatar
Thats pretty trick. Would you recommend this over any other wet kit for safety Dave?
Old Sep 24, 2005 | 12:10 PM
black_z's Avatar
Old Sep 24, 2005 | 07:56 PM
TwoFast4Lv's Avatar
L98/LT1 58MM plate?
How much juice? want at least two bill's on tap
hit my E-mail
Old Sep 25, 2005 | 12:56 PM
Noyzee's Avatar
8 second mod
Dave can you pm me a price for this kit with all the parts, but no bottle or brackets. dont need the switches either. thanks
Old Sep 26, 2005 | 04:21 PM
Noyzee,
Pm sent
Dave
Old Sep 26, 2005 | 04:40 PM
98Blubrd's Avatar
How much for just the plate?
Old Sep 29, 2005 | 09:05 PM
  #32
Brains's Avatar
Just finished up my install, and sprayed the GTO for the first time (75 shot). Feels like it should, power comes in nice and crisp without so much as a hiccup.
Dave, this plate works great! Thanks to all involved in making it and getting it to market
Old Sep 29, 2005 | 09:44 PM
  #33
Brains,
Thanks for the update.
Dave
Old Sep 29, 2005 | 10:28 PM
  #34
SDB's Avatar
SDB
This is where this plate will be nice...on cars like the GTO where there is an elbow that prevents using the MAF style kit....easier than a single nozzle in the air intake tube..
P.S.,
Dave, do you have the billet throttle switch/bracket out of the machine shop yet for 04 GTO?????
Scott-
Old Sep 30, 2005 | 05:05 AM
  #35
XTrooper's Avatar
Nice!
Old Sep 30, 2005 | 08:33 AM
  #36
Brains's Avatar
SDB, that's what I liked so much about it. I really didn't want to drill a hole in my intake tube for a nozzle, and didn't want to make the 90 degree turn either.
Not to mention, the plate install is very clean. The only part that's visible is the WOT switch (if you use a mechanical one), the top of the plate, and the lines heading under then fuel rail cover. I have the nitrous solenoid hidden under one of the covers, and the fuel solenoid on the front pass. cylinder head. I'm probably going to move the fuel solenoid under the other cover though, so it will be a nearly hidden kit without being a hidden kit Jet changes are such a breeze too, since they're right there on the top - and no nozzle to hold from turning. lol.
I was able to install this ENTIRE nitrous kit without drilling one hole in the car, or cutting into any wires -- anywhere. I can remove the kit without any traces that nitrous was ever used on the vehicle.
Old Sep 30, 2005 | 08:52 AM
  #37
cook_dw's Avatar
Got any dyno #'s on the kit yet?
Old Oct 3, 2005 | 12:28 AM
  #38
Comming soon.
Dave
Old Oct 3, 2005 | 12:54 AM
  #39
TrakDay's Avatar
Would this plate system be better than a single nozzle setup with my Procharged/cammed application!? And what can I jet down to with this kit. I would like teh capability to go as low as a 35shot!?
Old Oct 3, 2005 | 02:23 AM
  #40
GoldRust's Avatar
LS1TECH Sponsor / 7 Second Club
You could put as many 90's as it took to make it work. when you have pressure pushing the liquid out (fuel and nitrous) a few 90 degree turns are not going to make a bit of difference.
Dave it is great that someone got a plate kit out there that disributes well. Can you make one with a larger throttle body opening? This would work well for a second or third kit with a couple of direct ports. I know of a lil black car that this would really go good with
