Bmn Window Switch Problem
Old Sep 9, 2005 | 11:19 AM
mustgofasster's Avatar
Default Bmn Window Switch Problem
My Bmn Window Switch Is Not Working! I Have It On 8 Cl Mode Turn On 3000 Rpm Turn Off At 6000 Rpm. First Gear Lock Out Is Off. However The Green Light Does Not Come On Untill 5000 Rpms And Then It Turns Off At 6000. What The Hell?? And I Cant Feel Any Difference In Power. Has Anybody Else Had This Problem?
Old Sep 9, 2005 | 01:36 PM
Matt@HSW's Avatar
Try setting it to 4 cylinders for the LS1.
Matt
Old Sep 9, 2005 | 01:51 PM
Ouija's Avatar
Matt is exactly right. I had the same problem, put it in 4 cyl mode.
Old Sep 9, 2005 | 01:53 PM
redbandit98's Avatar
yes sir..they are correct..i had one and you must put it in 4cyl mode..
Old Sep 9, 2005 | 02:12 PM
XTrooper's Avatar
BTW, this isn't exclusive to the BMN rpm window switch. MSD, NX, etc; they all have to be put in 4-cylinder mode to work properly with the LS1 motor.
Old Sep 9, 2005 | 02:20 PM
okay i put it on 4 cyl mode, and the green light is still not coming on at what the dials are set at. When the green light does come on, I feel nothing> I tested the system yesterday without the window switch it worked fine.
Old Sep 9, 2005 | 02:29 PM
XTrooper's Avatar
In that case, it sounds like you may have a faulty unit.
Old Sep 9, 2005 | 03:11 PM
1ScrudeDude's Avatar
DANG, I wonder if mine will be faulty!!
I ordered mine at the same time! (Install in 2 weeks) Please update us after this gets sorted out.
Old Sep 9, 2005 | 03:24 PM
i know youve probably checked a thousand times..but make sure you have a GOOD ground..this is very important..even if you think you do..rig it up straight to your neg terminal or something and set the lower rpms to the lowest setpoint and throttle it with your hand under the hood and see if you get anything..also make dam sure you have it hooked to the right wire on your pcm..and make sure its got a good coneection..you may have accidently hooked it up to the wrong wire, or its not connected somehow. just go over everthing.im betting its not a faulty unit.
Old Sep 10, 2005 | 03:39 PM
BMN's Avatar
BMN
OK, sent ya a PM. Green light comming on means its reading. Looks like the pruple wire is hooked up wrong. It supplies a ground when active. Get back to the PM I sent ya with more of the details to the ?'s in there for ya. We'll get ya running.
