too lean?
Old Sep 17, 2005 | 06:41 PM
LETZ RUN's Avatar
Default too lean?
i think this tune is perfect. dyno guy said its too lean. what do ya'll think. i normally like this kinda tune on a forged piston though, i forgot that they werent.
Old Sep 17, 2005 | 08:59 PM
Robert56's Avatar
If it were mine I wouldn't run on the spray that lean. You can lean it slightly after your torque starts falling off, imo, that's how I have mine. 11.5 then 11.7/11.8.
Robert
Old Sep 17, 2005 | 09:02 PM
GREATWALLTA's Avatar
13 is fine anything leaner than a 13 you will have some problems. Spray would be same at 12 or so.
Old Sep 18, 2005 | 02:36 AM
Robert56's Avatar
You can run 13 on your set-up, but to give advice that 13 on the spray is ok is a little miss leading, imo.
Robert
Old Sep 18, 2005 | 10:23 PM
Elite_Hot_Rod's Avatar
No doubt. I'm going to agree with Robert on this 1. Your tune is to lean, I'd go 11.0 to 11.5:1 on the hose. You run a 13:1 on the bottle and something is going to melt.
Robert
Old Sep 18, 2005 | 10:29 PM
hellbents10's Avatar
LS1Tech Sponsor
Making that kind of power I would shoot for at least 12:1. More like 11.5:1 would be ideal like stated above.
Old Sep 18, 2005 | 10:34 PM
brad8266's Avatar
I had a A/F graph like that before but the car ran fine. I think I may have had a small exhaust leak or something though.
Old Sep 18, 2005 | 11:14 PM
Oh sorry about that, it was my falt for not reading the dyno sheet close. I did'nt even see the 100 shot run on there. yea, 13 is going to be too lean for you bud. 11 or so will be the savest bet. Sorry for the misleading it was my falt for not read the whole thing.
Old Sep 18, 2005 | 11:45 PM
Ben R's Avatar
Forget the dynojet wideband. That thing sucks.
Pull the plugs. It's the ONLY to way to be 100% sure.
Old Sep 19, 2005 | 12:03 AM
NVME88GT's Avatar
It's a good tune in a perfect world, but unfortunately we don't live in a perfect world. One bit of bad gas or a fuel supply hiccup and you're done. I run mine in the low 12:1 area and consider that pretty hairy. Good luck!
Old Sep 19, 2005 | 10:24 AM
LETZ RUN's Avatar
so theoretically, if i just change the 22 fuel to a 23 should be safe enough? or would you goto a 24? also, im wondering if a/f is gonna be the same going up in the jets, like if i goto a 200 shot, is it going to have the same a/f? So will i have to up the fuel jets in the bigger tune up also?
Old Sep 19, 2005 | 11:06 AM
If you change jets especially with a big shot it's always best to do a dyno pull to see where the A/F actually is.
