how do you hook up to your fuel system
Old Sep 19, 2005 | 02:00 PM
Odessastangslayer's Avatar
Default how do you hook up to your fuel system
i am new to nitrous and i just want to know how to get fuel to my fuel noid when i get ready to install my spray i need help with this if anyone has any iinput it would be greatly appreciated thanks in advance
Old Sep 19, 2005 | 02:04 PM
Noyzee's Avatar
8 second mod
not 100% sure, but i would think you could go right from the fitting on the stock fuel rail.
Old Sep 19, 2005 | 02:12 PM
thats what i thought to but im not sure how i would do this (what fittings i would need and would i need a bigger fuel pump to make up for the drain on it i was probably gonna get a bigger pump to help support this anyway i am only gonna spray a 100 or so wet shot)
Old Sep 19, 2005 | 02:19 PM
SiL3NtXWS6's Avatar
There should be a line that hooks directly to your stock fuel rail on driver's side (take off the black cap first..) You will need a shrader valve puller to remove the shrader valve inside the rail. You will also need to stick a phillips head screwdriver and push on the shrader valve to bleed the system before you remove it.
Noyzee's Avatar
8 second mod
i think a -4 an fitting fits that, so you would need a -4 hose whatever length, and a fitting for the noid.
remove the valve inside, and hook it up.
im not 100% sure as i have never done a setup like that, so let somone who has been there done that tell you mere.
Old Sep 19, 2005 | 02:50 PM
NitrousDirect's Avatar
Yes in most cases you can tap into your schraeder valve on your fuel rail that is used by mechanics to check your fuel pressure. You'll need a bicycle valve stem remover available at most any auto parts store be gentle and you can unscrew the stem.. make sure your vehicle is off please and then yes a -4 should hook right to it
Old Sep 19, 2005 | 03:24 PM
thanks alot for answering my question
Old Sep 19, 2005 | 03:30 PM
Noyzee's Avatar
8 second mod
im so smart. lol
good luck with it.
