View Poll Results: where should i put the bottle
on the driveshaft hump between the back seats
37.30%
in the spare tire well
62.70%
Voters: 764. You may not vote on this poll
where to mount bottle
Old Jan 17, 2007 | 10:13 PM
  #181
camar0corey's Avatar
I don't know much about LS1 cars, but I think on my LT1 car I have the factory Bose amp on that side?? Don't know if LS1 cars have anything over there??
Old Jan 17, 2007 | 10:26 PM
  #182
Fbody98's Avatar
I want it on the hump so i dont need the opener its easy access!
Old Jan 17, 2007 | 10:46 PM
  #183
Greek02SS's Avatar
if you have a 12 disc changer the panel is open on that side...so 'hiding' the bottle would be out of the question...
Old Jan 17, 2007 | 11:34 PM
  #184
nick_4.8sierra's Avatar
I don't have factory amp or 12 disc. Will the bottle fit on that side in my car?
Old Jan 18, 2007 | 07:39 PM
  #185
JRM96TA's Avatar
Does anyone have pictures of the 860 spare tire mount in a Firebird? I tryed intsalling mine and none of the holes seam to line up with any thing but it fits my buddys Camaro perfectly.
Old Jan 18, 2007 | 08:36 PM
  #186
Did it come with instructions? Your only supposed to use the center hole or something, and not use the spacer? Maybe someone with a scanner could send you the directions, I don't have a scanner. Not even sure I can find my instructions in the mess I have going on.
Old Jan 19, 2007 | 12:59 AM
  #187
Greek02SS's Avatar
I'm sure it probably will fit. i haven't looked at the space in comparisson to the bottle. i'll check it out tomorrow for you if you'd like. i have a 10# bottle btw
Old Jan 19, 2007 | 01:00 AM
  #188
Greek02SS's Avatar
theres pics a page or 2 back i thought?
Old Jan 19, 2007 | 07:36 AM
  #189
NHRATA01's Avatar
Yeah I just installed one last week. You only use one of the holes on a Firebird, near where the piece that holds the spare tire attaches. Then you have to drill two holes on the other side that match the holes in the plate.
Old Jan 19, 2007 | 08:01 AM
  #190
860 Performance's Avatar
Here is a link to the instructions
http://www.860performance.com/files/...structions.pdf
Like NHRATA01 said, Firebirds use different holes than a Camaro uses.
Hope that helps.
Vinny
Old Jan 19, 2007 | 01:37 PM
  #191
67GoatPimp's Avatar
I used a nitro dave's mounting bracket that I had powder coated in wrinkle black. I think it looks much better this way, it almost perectly matches the center console. I have yet to install the blow down tube, It will be flexible and out under the rear passenger seat, and when my heater and remote gauge get here, I'll use a small length of hose to hide the sensors under the seat or bracket to keep it from looking cluttered. I also have a set of NOS quick release brackets on the way now. Too bad this thing isn't drilled for them.
Old Jan 19, 2007 | 02:16 PM
  #192
JRM96TA's Avatar
Thank You, all this helps it appears that my spare tire/power antenna bracket sticks out to far(or the bracket has extra metal). It looks like I can make it work by cuting about 1 1/2" off the area where the 860 mount is bent down.
Old Jan 19, 2007 | 06:08 PM
  #193
NHRATA01's Avatar
Here's a pic of the 860 mount plate in my car, if it helps:
Old Jan 19, 2007 | 09:36 PM
  #194
That would be great. Let me know when you do. I would be it's FREEZING down here in Texas. lol
Thanks!!
Old Jan 20, 2007 | 12:31 PM
  #195
HeavyWeight's Avatar
Anyone have 2 bottles mounted
Old Jan 20, 2007 | 01:34 PM
  #196
Greek02SS's Avatar
Thanks!!
there's something else on that side, an extra hump....for me at least, i wouldn't be able to fit it there. but you'rs might be different, just pull the panel and check it i guess, sorry!
Old Jan 20, 2007 | 01:52 PM
  #197
Sprayed1998's Avatar
I just got this ND mounting plate and In have the NOS brackets on them, the 7" Dia. ones but no quick release, the fronts line up perfect but i had to drill new holes in the rear bracket to make it fit on the mounting plate, it was about 1" too thin.
Old Jan 20, 2007 | 02:50 PM
  #198
2000Hawk's Avatar
Heres a few photos of the bottle mounted in my car. Through the windshield its hard to see because of the tinted windows. I love how it looks, it belongs on the tunnel.
And here is a photo of my nitrous pressure gauge:
-Joel
Old Jan 22, 2007 | 10:59 AM
  #199
So would a 15 lb. bottle with a remote opener fit in the spare tire spot with the 860 mount? Thinking if I sell the zex kit and get the NOS one I might bump up the bottle size to 15 so I wouldn't have to go get refills as much.
Old Jan 22, 2007 | 02:48 PM
  #200
02NHRAtransAm's Avatar
Nothing fancy here... just a bottle, opener, warmer , and a blanket
