View Poll Results: where should i put the bottle
on the driveshaft hump between the back seats
37.30%
in the spare tire well
62.70%
Voters: 764. You may not vote on this poll
where to mount bottle
Old May 23, 2007 | 11:37 PM
  #281
slowpoke96z28's Avatar
tin can on wheels. i dont plan on honda-ing the car out by pulling all the interioir and rear seat and hiding the bottle under a heavy *** speakerbox. that **** would get stolen the first time the owner left it.
Old Jun 27, 2007 | 10:00 AM
  #282
1FSTLS1's Avatar
Ok so my T-tops and food from trips to the market have to go in the back seat as my rear is full of amps and subs. So guess i will be loosing my spare tire. I am going to try to fab a mount with a fire extinguisher holder. Dumb question do i really need a remote bottle opener. Cant i just turn it on then go to the market even if i dont spray. Just want to be ready for that punk in his civic. Can you leave the bottle open 24x7??
Old Jun 27, 2007 | 12:47 PM
  #283
99_Z_155's Avatar
Here is my setup. i like it between the seats. i have subs in the back, and i didnt have to buy the remote guage and bottle opener. it gets alot of wow factor out of it too. for some reason people around here dont believe you when you say you have nitrous. thats when i just point at the bottle. "there you have it..."
EDIT: I wouldnt recommed leaving the bottle open all the time. i think it messes with the nitrous solenoid. just open it when you go out, and when you get home, just purge the line. thats what it do.
Old Jun 27, 2007 | 03:28 PM
  #284
camar0corey's Avatar
No, you can't leave your bottle open all the time.
The inbetween the seats is nice. I decided a long time ago to run the 860 spare tire mount. Which still doesn't have a bottle in it. I'm about $350 short on getting the nitrous outlet 58mm plate system.
Old Jun 28, 2007 | 01:49 PM
  #285
1FSTLS1's Avatar
Guys with the bottle between the seats what do the cops say when you get pulled over????
Old Jun 28, 2007 | 02:32 PM
  #286
BobDoLe's Avatar
nothing.
i tore the bottle and mount off the hump and stuffed it behind the seat before he walked up to the car.
Old Jun 28, 2007 | 05:03 PM
  #287
transamfreak01's Avatar
its not illegal. the cops arent going to give you a ticket for a nitrous bottle in the back.
Old Jun 28, 2007 | 10:05 PM
  #288
Originally Posted by BobDoLe
...i tore the bottle and mount off the hump and stuffed it behind the seat before he walked up to the car.
thats a good way to get shot here in Harris county. never thought about the cop factor though. thats one positive to having it in the spare tire well.
Old Jun 29, 2007 | 06:15 AM
  #289
1FSTLS1's Avatar
You must be awfull fast to take the bottle out while still in your seat.
Old Jun 29, 2007 | 05:08 PM
  #290
stainless40cal's Avatar
Where can i get this bracket...... Its the second post down with the two pics .......
https://ls1tech.com/forums/showthrea...&page=12&pp=20
Old Aug 15, 2007 | 12:35 AM
  #291
mulot30th's Avatar
I do have my 20# nitrous bottle in the spare tire well.
Old Aug 15, 2007 | 12:58 AM
  #292
BayAreaSS's Avatar
I like having my bottle in the spare tire area
Old Aug 15, 2007 | 09:24 AM
  #293
408z28's Avatar
Daily driver = spare tire well mount........gives more space in the passenger area + its easier to route your blowdown tube.
Track car = trans tunnel mount...... easier access, and quicker bottle changes
Just my .02
Old Aug 16, 2007 | 09:49 PM
  #294
Empatho's Avatar
I just ordered a tunnel mount from Nitrous Outlet for my DD Z28, so the bottle is going on the hump. Once I get the mount Im going to cover it with carpet Ill get some pics when I get it all done.
Old Aug 17, 2007 | 10:31 PM
  #295
yeah, i'd like to see how it looks with carpeting. the stainless steel as it comes stands out too much for me.
Old Aug 18, 2007 | 03:23 AM
  #296
Empatho's Avatar
I went to Home Depot today and got some carpet and Adhesive spray, Im just waiting to get the mount so I can start working on it, I hope I get it this monday.
Old Aug 18, 2007 | 10:10 AM
  #297
Only reason I regret putting it in the spare tire area is now I need to get a remote bottle opener. In a way that is better though, I'd rather flip a switch than open the bottle by hand, probably miss when the light goes green, or personally I wouldn't want to try to open it at highway speeds if a cobra or something rolled on up.
Old Aug 18, 2007 | 07:58 PM
  #298
motownZ's Avatar
now when drilling into the trans hump is there anything to watch out for? and can a reg NX kit brakets work good if you dont want to use the bracket from after market??
Old Aug 22, 2007 | 03:11 AM
  #299
brantsz's Avatar
Originally Posted by WickedRamAirWS6
I have an F-Body and mounted my 10 lb. bottle in rear hatch area behind the rear seat using the two bolts already in place for the tie down points, you know the two triangle shaped clasps. I did this to prevent from having to drill holes in my car. i fabbed the bracket out of 1/4" X 1" flat stock and actually raised the bottle up off the trunk surface so it's at an angle kinda up in your face. it was easliy seen through the rear glass..till i painted the bottle and brackets black...now it's kinda in your face stealth style...
That is exactly the way I did it also, No holes in your car etc. But I used a 4" wide 16" 1/8"thick piece of stainless to run between the two factory bolt holes. I will put some pics up in a day or so.
Old Aug 23, 2007 | 09:18 PM
  #300
Empatho's Avatar
well I got my bracket and started working on it, I got the pics that I promised It was really easy to do it took me a couple of minutes, I think it came out good and it looks better in person the pics are not that good but better then nothing ... lol
