Dry Dyno Run
Thanks
Robert
Robert
Robert
Robert
Robert
Robert
Robert
Also the vast majority of your nitrous will be coming through as dry...this means the wet has a smaller impact on flow through the MAF.
...though less than what you'd get with a nice TNT 150 hit, it is certainly less violent.
Robert
Robert
and Im not running any 1.5 60's ....
Thanks
Robert
My list :
Dry kit
Window Switch
Bottle Heater
NGK TR6s
Anything else? Are you still running stock injectors?
My list :
Dry kit
Window Switch
Bottle Heater
NGK TR6s
Robert
Robert
Robert
Robert
Robert
I think a third stage is a little overkill. We only run two on ATVRacers car. Just shrink the front stage a little and bring the rest in up top. Timing and fueling can help soften the hit if need be as well as make it that much safer
We have seen very big changes on the IAT temps depending on ambient, ATVs car has been 9.9s in 110 degree heat and saw only 40-50 degree IATs, and on cool days/10.0s on just the front stage it has seen -20 degrees. Never had both on blast on a cold day to see how far it would go
CAT3 -"convert over to a -6 mainline, the -4 aint going to work much longer"
ATV is running a 4 an feed, and its running thru a y block which cuts it down even a little more. You can make a good chuck of power thru the 4, Dave seems to think its maxed around 250. Eventually I guess we may jet it up to find out where it maxes out before he switches over to 6 AN feed
Black02SS, Im going to tell Dirk you want to put the MAF on
