Dry Dyno Run
Black02SS, Im going to tell Dirk you want to put the MAF on
I am really partial not having it, but I am strongly liking the idea of a dry more and more. We have seen very big changes on the IAT temps depending on ambient, ATVs car has been 9.9s in 110 degree heat and saw only 40-50 degree IATs, and on cool days/10.0s on just the front stage it has seen -20 degrees. Never had both on blast on a cold day to see how far it would go
CAT3 -"convert over to a -6 mainline, the -4 aint going to work much longer"
ATV is running a 4 an feed, and its running thru a y block which cuts it down even a little more. You can make a good chuck of power thru the 4, Dave seems to think its maxed around 250. Eventually I guess we may jet it up to find out where it maxes out before he switches over to 6 AN feed
On the iat thing, I guess I am lucky living in the NW as we generally only see 80* Temps as max ambient air. So, I think the IAT vs fuel adder has some real benifits to offer. also, using a true ram air will minimise the intake air temp, such as a Vararam on the vettes. Ambient air compared to under hood air can be very different in temps.
On the 4an line NX Jeremy had stated that in can flow a max of 440rwhp. I sure wish we could get an absolute answer on this, as I am also running a 4an and wonder where I will run out?
Robert
Robert
Robert
I played with using the temp tables for a fewthings for Waynes car but we see such wide temp variations here its hard to pin it down
