N02 purge??
Old Oct 4, 2005 | 04:57 PM
fastbasser's Avatar
Default N02 purge??
If you have N02 in your system, can you always see the purge? I had heated my bottle to 800 lbs, (from 650) hit the purge and saw none come out. I could hear it but not see it.
Is this just compressed and heated air?
Thanks
Old Oct 4, 2005 | 05:01 PM
2001z's Avatar
umm you might have to hit it twice how long is the purge line? if you cant see it after a couple of purges your most likely empty ,and all is left is compressed air . that is just my .02
Old Oct 4, 2005 | 05:06 PM
Matt@HSW's Avatar
The weather will play into it too as well as the size (orifice) of your purge line.
Matt
Thanks
Old Oct 4, 2005 | 05:26 PM
fastbasser's Avatar
Matt,
I/m using 3/16" line for my purge. When the bottle is full, (about 800 psi cold), I can see it as clear as hell.
Thanks
Old Oct 4, 2005 | 07:47 PM
Matt@HSW's Avatar
Do you know how many pounds of nitrous you had left in the bottle? It's possible that it was just air.
Matt
Old Oct 4, 2005 | 08:06 PM
fastbasser's Avatar
Matt,
I dont know. Gonna have to take it out and weigh it . Guess I thought if I turned the bottle on cold and it had 600psi, that meant there was nitrous in it..
Thanks
Vinnie
