New wet #'s vs dry
baseline 315hp 333tq
NOS 418hp 463tq
New wet converison
baseline 323hp 340tq
NOS 433hp 526tp
For some reason I can't flow anymore nitrous that. I running a .82 nos jet, so I have a restriction somewhere. So I have a 110 rwhp gain and a 186 rwtq. But good golly can you feel the diff.
Anyways my set is 2 NOS noids from the 05177 kit with a fogger and fuel noid from dynotune.
NOS 418hp 463tq
New wet converison
NOS 433hp 526tp
The answer you are looking for is that the NOS powershot solenoids that you have (from the 5177 kit) only flow a 150 shot or .063 jet. They won't flow any more than that. I suggest you get in touch with nitro dave and have him hook you up with the parts list. Here is my parts list, he can make sure it's right (that's who I got it from anyway)....
NX Nitrous Solenoid .093(stage 6)-#15200-$118.00
NX -4an SHO Hose-#10124-$24.00
NX -4an 1/8" fitting for solenoid-#16109-$4.40
and the last part does not have a part number..it's a BRAND new part. It can flow up to a 300 shot or .093 orifice through a single dry nozzle...
NX BIG SHOT SINGLE Dry nozzle-$15
prices might have changed, I'm not sure. The -4an feedline is good up to or past a 300 shot though. Your restriction lies in the solenoids forward (noids, feedline, and nozzle). Another option is to split the two NOS noids up using a "Y" fitting coming off the main 4an feed line and run two .040 jets to get about the same effect as the .082 jet, or about a 250 shot.
Of course the wet system will make more torque than the dry system.Thats a given.
Take and get a better Nitrous soilenoid so that you can safely run one solenoid and then your horse power will pick up also.
Dave
I'll replace the noids then. Thanks guys
One thing about running redundant noids on a wet system, not good. You have just doubled the chance for failure on the nitrous side. It is not a case of inferior noids being used in redunantcy on the 5177 but rather an added safety thing. really the only thing that can go wrong on a dry hit is the n2o noid sticking open and with two, you'll never have both sticking open at the same time. so the implications that the power shot needs two because they are less than is nonsense. With that said, yes NX has better noids than the powershots, but so does NOS.
Yes, it is a given that wet hits make a little more torque, but there are certainly trade offs for that extra torque. If your happy that all that counts. stick with it you'll figure it out.
By the way, there have been more than a few guys that have split up the noids on the 5177 and ran no jets and made 300 or so HP, so flowing 150 each...
Robert
Ricky
Robert
One more thing, sometimes wet kits will not be at there advertised hp level, for various reasons, doesn't mean kit is bad though.
Robert
Robert
I'm going to get a new nitrous noid and run the 4an feed line striaght to it.(with a filter) Then run my 3an line to the fogger. I will double check the lines I have for blockage. This thing is a different car now, I didn't think I was gonna feel the diff that much but I do. I'm pretty happy right now(feel wise) but I don't like the way I have it. It actually broke the tires loose 2 times at 45-50 in 2nd gear. For some reason though I felt safer with the dry, I'm alittle weary spraying right now.
Robert
NOS 418hp 463tq
New wet converison
NOS 433hp 526tp
