nitrous question for a 99 z28 m6
Old Oct 29, 2005 | 12:45 AM
pugads650's Avatar
Default nitrous question for a 99 z28 m6
i just purchased a 99 z28 m6 its pretty much stock exept for the exhaust and the lid i want to be able to catch my brother on the 1/8 mile his best time is 7.996 at 94mph in his 87 gn would a wet nitrous kit get me there im getting 17 inch bfg drag radial this weekend i want to do this safetly this is my everyday car and i dont really wont to break it
i have a 700.00 budjet for the nitrous a 500.00 for anything else that i need to get me in the 7s in the 1/8th
also i heard something about the nitrous puddling in the intake and causing it blow up is there anything you can do to prevent this.
i dont plan to use the nitrous everyday just on the track thanks.
john
Old Oct 29, 2005 | 02:08 AM
pugads650's Avatar
what nitrous kit would you guy's recomend for my car thanks
john
Old Oct 29, 2005 | 12:33 PM
code4's Avatar
john
I went with a dry nitrous kit from Dynotune. It is very simple & won't break the bank. This is the kit I ordered: http://www.dynotunenitrous.com/store...?idproduct=118
I added a 2nd solenoid, a nitrous filter, a digital MSD window switch, a pressure gauge & it was still under $600 ( if I remember correctly). I spray from 3K rpm to 5.5K rpm controlled by the window switch. I installed tr6 spark plugs and I hooked up a LM1 wideband to make sure I wasn't going too lean when I sprayed. When using a dry kit this is the main concern as you are relying on your fuel injectors to spray the correct amount of fuel.
Pic of the solenoids/spray nozzle, you can see the nitrous filter just in front of the solenoids.
I mounted the bottle here:
I mounted the Digital window switch in the console
Old Oct 29, 2005 | 12:48 PM
slowpoke96z28's Avatar
that is a clean install, code4. where did you put you switches? pugads650, i'd stay away from the drag radials at the track if you don't want to break anything unless you have a 12 bolt. the D/R's hook good on a crappy surface, you put them on a prepped track, you'll being going through rear ends like crazy. a 100 or 125 shot should be more than enogh to run the number you're looking for, though.
Old Oct 29, 2005 | 04:19 PM
pugads650's Avatar
so should i get a wet or dry kit i want to do this as safely as possible
Old Oct 29, 2005 | 04:32 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
For the LS1, the safe bet is just get the dry kit. Simple hookup and easy on the wallet.
www.DynoTuneNitrous.com You will have plenty of money left over for a heater kit to!
Cheers
Dan
Old Oct 29, 2005 | 07:10 PM
pugads650's Avatar
would that be able to get me in to the 7s
Old Oct 29, 2005 | 10:16 PM
code4's Avatar
In the ash tray.
Old Oct 31, 2005 | 09:22 AM
Nitro Dave's Nitrous Outlet's Avatar
Considering your budget I suggest the dry kit. If you shop wisely you can get a system that can be easily upgraded to a wet system later. I suggest a window switch and a heater at the bare minimum. Oh and a nitrous pressure gauge.
Dave
