install question
Old Nov 25, 2005 | 09:20 PM
raven_450's Avatar
Default msd analog window switch install question
Do you need to use a wot switch with a window switch for nitrous or can you just use the window switch? and if i just use the window switch what would be the down side?
Old Nov 25, 2005 | 11:14 PM
brad8266's Avatar
LOL, you need a WOT switch or a push button activate switch. Without either of these the window switch will turn on everytime you hit the specified rpm, regardless of where the throttle is, you dont want that to happen. Get yourself a WOT and window switch. The downside to using just a window switch would be a blown up motor, which is almost guaranteed if the nitrous turns on at 1/2 throttle at 3000 rpm's.
Old Nov 26, 2005 | 11:17 AM
2001z's Avatar
you need a wot switch to be safe. Lots of people i have talked to and seen dont use alot of the safty devices or buy the basic kits . To me if you cant afford to buy the safty devices then you wont be able to afford to spray to much anyways so no use even trying. becouse all your gonna do is break something and blame it on the nos.
Old Nov 26, 2005 | 12:50 PM
charlie c5's Avatar
The window switch is good protection for the transmission. The switch turns your syston off during shift points.
Old Nov 26, 2005 | 01:24 PM
raven_450's Avatar
i have the wot switch its in my friends car so i guess hes not gonna have nitrous lol, thanks for the replys i have another ? though where do i run the white wire to(tach wire) ?
Old Nov 26, 2005 | 01:27 PM
brad8266's Avatar
Number 10 wire (tach signal) goes to the window switch. Which wire on the switch it goes to depends on the particular window switch you are using.
Old Nov 26, 2005 | 01:29 PM
Cheater's Avatar
LOL i know when my throttle is wide open, use a toggle switch to power the window switch and if you have been driving for more than 2 days, you will know that when the pedal is all the way on the floor you throttle is wide open.
Old Nov 26, 2005 | 06:13 PM
brad8266's Avatar
Yeah or this way will work also.
Old Nov 27, 2005 | 01:23 AM
LoWeLL216's Avatar
Yeah, there's alot of things you can do...Doesn't mean its a good idea...
