Just Installed Nitrious...need input???
Old Nov 30, 2005 | 11:50 PM
2002LS1Z28's Avatar
Default Just Installed Nitrious...need input???
i just installed a zex wet kit on my car...i have only the 75 hp jets installed rite now because i havnt had the time to regap the plugs...i zip tied my nitrious feed lines onto my fuel lines....i heard this may be a problem??? If i gap my plugs to 0.35 and i put the 125 hp jets am i safe with out retarding the timing like the instructions say??? also i have not yet purchaced any extra safety equiptment like a FPSS or a window switch....am i stupid to evan try using the nitrious with out the extra saftey equiptment???? where should i go from here??? i am new to nitrious so any info will help....
Old Nov 30, 2005 | 11:58 PM
white2001s10's Avatar
Before you make a full 1/4 mile pass with the 125 shot make sure you have everything in order.
Running a cooler plug with a tighter gap is best, and it helps to run the engine cooler when you're spraying.
You should be okay though as long as your KR is working.
A few seconds at a time shouldn't hurt just the way it is. It's the time factor that builds up the heat in the chambers.
Old Dec 1, 2005 | 01:58 AM
BrianC98Z28's Avatar
in a 6spd its a must to atleast have a window switch. I wouldnt personally spray without atleast that.
Old Dec 1, 2005 | 02:02 AM
383LQ4SS's Avatar
without a window switch just be sure to pay attention to your activation rpm point. Use the general rule of not spraying below 3000 rpm and youll be fine. But its nice to get a window switch and remove the human factor from the equation. Many have run without one...including myself. But its highly recomended.
As for plugs and gap...what plugs do you have in there now? As long as they arent stock plugs youll probably be ok. If they are TR55s or the same heat range I would stay on your 75 shot until you switch them to TR6. You want to tighten the gap to around .038 or less when running the 125+ shot and be a heat range colder like the Tr6.
As far as FPSS you can get one...they are cheap and easy to install. I personally like a fuel pressure gauge to monitor fuel pressure status. Especially if your running the stock pump that is very prone to failure.
And lastly...its nice to get on a dyno with wideband to make a few nitrous pulls to check AF to ensure its all working properly. If you cant get to one...pull a plug immediately after spraying and read it. Do a search on plug reading for pics.
Anyways...welcome to the sight and start reading and using the search button.
Old Dec 2, 2005 | 02:27 AM
2002LS1Z28's Avatar
i have stock plugs now....where do i get the tr6 plugs?
Old Dec 2, 2005 | 09:54 AM
Nitro Dave's Nitrous Outlet's Avatar
We stock TR6 spark plugs. Or you can check your local Oriellys or Napa.
Dave
Old Dec 3, 2005 | 02:18 AM
2002LS1Z28's Avatar
tr6 is the part number???? what gap??? i would buy them from you but i need them asap
Old Dec 3, 2005 | 03:29 AM
SSDriver's Avatar
The part number is 4177. I gap them at .38
