who all has the timming tuner??
Old Dec 12, 2005 | 02:00 AM
monkey11's Avatar
Default who all has the timming tuner??
i was just woundering how this thing works? it sounds good. i'm just doing some shopping for some nitrous parts. i would like to know how the tuner is turned on, and how it is wired up, how much timming can you retard, do you like it, any problems with it? etc. i'm running dry, just so you know. thanks in advance!
Old Dec 12, 2005 | 03:12 AM
monkey11's Avatar
maybe this will help?
http://www.nitrousoutlet.com/outlet/...section_id=138
Old Dec 12, 2005 | 07:13 AM
JoeyAnderson's Avatar
I'll be getting one as well and I'm curious too.
Good thread!
Old Dec 12, 2005 | 08:03 AM
Matt@HSW's Avatar
PM me with your email address and I'll send you guys a copy of the instructions.
Thanks,
Matt
Old Dec 12, 2005 | 04:42 PM
4bangermustang's Avatar
I have it....WORKS awesome. Can running good timing for motor passes and not have to worry about tuning your computer for a nitrous pass.
Old Dec 13, 2005 | 12:11 AM
SSDriver's Avatar
I've had it for a while now and it has worked great for me without any problems so far.
Old Dec 13, 2005 | 02:10 AM
Robert56's Avatar
For you guys running a dry hit, no timing tuner is needed. In my web is a proven method to pull timing only on the spray, and not affect n/a timing. It's done in your tune, write up explains how to.
Robert
Old Dec 13, 2005 | 07:11 AM
Pwebbz28's Avatar
I HIGHLY agree with Robert on this. I used this method on my 92z a LONG time ago and wasnt even aware. IAT sensor is tapped into the intake.
The other good thing about a timing tuner is you can use it as a window switch.
Old Dec 13, 2005 | 07:45 AM
TNTramair's Avatar
timing tuner works great...also has built in delay feature and window switch.
Old Dec 13, 2005 | 10:13 AM
Nitro Dave's Nitrous Outlet's Avatar
The timing tuner works great. I would suggest it to be able to run a NA tune to its full potential and then pull the timing for the spray.
Here are the instructions.
http://www.fullthrottletech.com/atta...ttachmentid=82
Dave
Old Dec 13, 2005 | 02:58 PM
2002z28's Avatar
dave,
when i bought all my nitrous goodies from you i was under the impression that i would not need a timing tuner with a 100 wet shot. does this still hold true?
thanks,
justin
Old Dec 13, 2005 | 03:39 PM
mike c.'s Avatar
it's an awsome part and i wish i bought it long before i did.
Old Dec 13, 2005 | 04:55 PM
SDB's Avatar
SDB
They work great...I have one on my camaro, one on my GTO, and one for sale! $155 shipped...anyone interested??
sdbojrab@comcast.net
Old Dec 13, 2005 | 06:04 PM
2002z28's Avatar
sdb i talked to you this past summer at halls. i had the nbm z with chrome zr1's. i was hoping that i dont need a timing tuner since im only running a 100 shot, but we will see what dave says.
justin
Old Dec 13, 2005 | 09:08 PM
SDB's Avatar
SDB
justin
You won't need to retard timing more than likely with only a 100 shot...BUT you will need a rpm window switch, and for that reason I would recommend a timing tuner. Since you have some mods allready, I would make sure to monitor it with some software to make sure your not getting any KR on the bottle. I have EFI Live professional and a laptop to do this if you want. Just email me and I will give you my cell...
Old Dec 13, 2005 | 09:27 PM
Robert56's Avatar
I agree, except on getting a timing tuner. More than likely no timing pull is needed upto 150+hp hit, unless aftermarket tune was added. So the extra $$ for a timing tuner compared to a reg ws is wasted, imo.
Robert
Old Dec 13, 2005 | 10:27 PM
Correct unless someone has advanced your toimming through a tune you will not need to retard timing.
Dave
Old Dec 13, 2005 | 10:33 PM
SDB's Avatar
SDB
Robert
True enough, the $289 is a lot for just the rpm switch...but I have a used one (that came back from fullthrottlespeed with a new case and fully checked out) that I will sell for $155 shipped. Its nice to have the nitrous delay feature as well as the ability to advance/retard timing for later mods as well as extreme temps.
SDB
Old Aug 2, 2006 | 06:47 PM
casado's Avatar
I got my tune from Bryan (PCMforless) probably the timming is pretty advance...how much nitrous can I run without a timming tuner or none of that fancy stuff???
I'm new on this nitrous world...I'm learning
Old Aug 3, 2006 | 09:07 AM
Matt@HSW's Avatar
Depending on how much was added along with how safe you want to play it, I would say none. Try to find out how much timing you have and either pull it or run a higher octane fuel.
Matt
