next nitrous breakthrough
Old Dec 19, 2005 | 01:52 PM
  #41
Ben R's Avatar
Originally Posted by N20GMC
We have a wide band 02 in each tube of mikes car but not shannon's, they also have egt's in each tube but they dont tune off any of that.
The only other fittings on the regulators go to the race pack.
And I'm a dumbass for not thinking of that.
What are you guys' plans for this upcoming season? Are you going to run both the IHRA and NHRA circuits? What about the ADRL? Where are you going to run the Pro-Street car?
Old Dec 19, 2005 | 02:52 PM
  #42
NXRICKY's Avatar
Closed ex-Sponsor Account
I could see 8 sensors plugged into a a pcm so you can tune each hole via o2 reading, and set the computer to do it automaticly...
Ricky
Old Dec 19, 2005 | 09:18 PM
  #43
N20GMC's Avatar
Hit the IHRA hard like this year and then do whatever we can that doesnt interfere with IHRA. I think they are planning on running alot of Pro Street races (its easy money) j/k. And some ADRL when time allows.
NHRA hates nitrous. So we probably wont run many if any at all.
Old Dec 19, 2005 | 11:51 PM
  #44
GrannySShifting's Avatar
How about a fuel thats REALLY suited to pure nitrous cars.
Old Dec 20, 2005 | 09:01 AM
  #45
cyipher's Avatar
How about running pure oxygen?? who needs nitrogen anyways...
Old Dec 20, 2005 | 11:18 AM
  #46
STANG KILLA SS 2's Avatar
its rumored that some people are playing with the actual chemical make-up. experimenting with N202 and others......shhhhh
Old Dec 20, 2005 | 07:19 PM
  #47
N20GMC's Avatar
VP makes gas called N20, we used to run it but we run C-23 now.
Old Dec 20, 2005 | 07:28 PM
  #48
Ben R's Avatar
It would be pretty funny to see you guys go beat-up on Vinny in the NMCA. It wouldn't be much fun to get beat up on by the guys that help sponsor you.
In all seriousness I saw the pictures of his new 68 on your website and it looks awesome! And I hope you guys make the ADRL race in Houston.
Old Dec 21, 2005 | 10:15 AM
  #49
NXJeremy's Avatar
N2OGMC- Why the change in fuels? I've noticed that the Nitrous Fuel has a higher octane but a lower specific gravity than the C-23. Was the change due to the specific gravity of the fuels, or a different reason? Just curious. Thanks.
Old Dec 21, 2005 | 11:28 AM
  #50
ITSTOCK's Avatar
Originally Posted by JS
I'd like to see a dry shot after the MAF controlled by the stock PCM as the N20 engages...I'd like to see a retard added with it and a shut off if AF got too high....THAT WOULD BE THE CATS MEOW
The dynojet WBC already has the a/f feature....they are currently working on adding the TRUE window switch in to the program (I use the DJ WBC and have the nitrous engage at 3500rpms, and it is set to stop spraying if it goes leaner than 12.5). I am spraying it post maf (after the MAF) also, however, at WOT, my MAF commands an a/f ratio of 9.2:1.
I'm also sure that it wouldn't be too hard to add in a timing retard module, as the technology already exists and is readily available.
Old Dec 21, 2005 | 11:30 AM
  #51
ITSTOCK's Avatar
Originally Posted by cantdrv65
How about controlling nitrous flow with a MASS FLOW CONTROLLER? It measures nitrous temp, pressure, and density then controls the flow no matter what each variable is at the time. Mass flow controllers are certainly not cheap and the ones we use in industrial applications are kinda large, but every piece of technology starts out a little large right?
It already exists to a point...
http://www.snowtechmagazine.com/arti...us/nitrous.php
Old Dec 21, 2005 | 12:56 PM
  #52
Ben R's Avatar
I was wondering the same thing. Have you guys used the C-23+? It has the same specific gravity but a slightly higher octane rating.
Old Dec 22, 2005 | 08:56 PM
  #53
N20GMC's Avatar
I will have to ask. I have just seen the old N20 drums out back and the 23 inside. I will ask and get back. Although Torco was pissed at us for running VP stickers and gas in there shootout. Then VP got mad because all Torco's crap.
Yea we help them out alot, and he has an awesome car. But it will take alot more than that to beat us. We will probably beat up on him some we have alot of things to test in the P/S car that we have just came out with.
Old Dec 22, 2005 | 09:16 PM
  #54
cantdrv65's Avatar
Post
Originally Posted by ITSTOCK
Hmmm interesting, the only way that nozzle could work is to actual vary the size of the orfice based on supply pressure. It must have some type of needle and seat with a calibrated spring... Pretty cool idea, I wonder if they could apply it to flow larger shots?
Old Dec 22, 2005 | 10:53 PM
  #55
Ben R's Avatar
Can't make everybody happy I guess.
David Hance is going to race NMCA Pro Street this year with his Twin-Turbo Mustang instead of NMRA Pro 5.0. It could be a very good year this year for the NMCA in that class.
