Spray before air filter?
Old Dec 22, 2005 | 11:12 AM
jimmyblue's Avatar
Moderator
Default Spray before air filter?
Seen that people remove the MAF screen for
icing reasons.
It looks like the best location for hidden nozzles,
on my car, would be down in the cold air induction
ducting. This would put the super-cold running
through the paper air filter. Do people do this, or
is it just another icing problem waiting to happen?
Is the larger area of the filter enough to make it
a non-problem?
Old Dec 22, 2005 | 11:30 AM
DynotuneN2O's Avatar
LS1TECH Sponsor
If its a small shot like 75hp it is ok, not ideal but ive seen folks do it.... It does lose a bit of the "cold" air flow...I still would recommend mounting on the other side of the filter. I think nitro dave sells a kit for this....Hidden internal spray nozzles....
Dan
Old Dec 22, 2005 | 11:43 AM
white2001s10's Avatar
The filter would clog with ice in just a few seconds.
I won't hurt anything but you'll notice a big power loss.
Old Dec 22, 2005 | 12:12 PM
NitrousDirect's Avatar
Do not spray through your filter
Old Dec 22, 2005 | 12:30 PM
1BAD02WS6's Avatar
maybe check out Daves Halo kit that sits under the lid ontop of the filter.
Old Dec 22, 2005 | 03:18 PM
Cheater's Avatar
Oh my god,why would anyone want to spray into the filter lol lol
Old Dec 22, 2005 | 08:00 PM
Robert56's Avatar
My buddy sprayed a dualnozzle dry directly into his filter and froze it then blasted two holes into it. But like Dean said, some do it. sneak it in a air tube above filter, that's how vette guys hide it some times.
Robert
Old Dec 23, 2005 | 01:57 AM
Nitro Dave's Nitrous Outlet's Avatar
We sell just the Halo spray bar seperatly if you already have a system.If you do not have a system the Halo is the way to go...
Dave
Old Dec 23, 2005 | 08:17 AM
jimmyblue's Avatar
Moderator
What section is this halo bar found in? I couldn't find it
on the site. I have all the stuff to cobble up the system
but just need the last couple of inches, sooper sekrit
style.
Last night I thunk up another way, modifying the two
brass nozzles I have by busting off the angle end and
soldering on a couple of inches of steel tubing, cut at
an angle so that they would pierce the air filter in two
spots and barely stick through. Then I can mount all
the hose hardware below the lower airbox plastic and
just have the "periscopes" sticking up.
Old Dec 23, 2005 | 08:25 AM
LS1TECH Sponsor
Cover the single nozzel with rubber hose,use 1 foot,then cover the rest of the line with plastic electrical tubing. folks think thier looking at a emission device...works like a champ.
Old Dec 23, 2005 | 11:32 AM
Jimmy Blue.
The Halo bar is not on the current web site.Its on the new one though..LOL
Here is a pic of one with the inlet fitting through the air lid.We offer the hidden version with the inlet fitting through the filter.
Old Dec 23, 2005 | 11:57 AM
Fogle07's Avatar
does that shoot nitrous out or does it just get really cold?
Old Dec 24, 2005 | 01:24 PM
slowpoke96z28's Avatar
it sprays nitrous
Old Dec 24, 2005 | 01:35 PM
G-Body's Avatar
sawzall wielding director
Why not run the lines under the intake manifold and drill the bottom of the manifold? Come from ontop of the trans route them under the manifold to just behind the TB and up into the manifold.
Old Dec 24, 2005 | 05:19 PM
greekss's Avatar
cuz i think he wants a dry shot.....
